NagEvLogCtrl Installation - Windows 2008 Server R2
citpaj
Post by citpaj »
Can anyone tell me the exact steps to install NagEvLogCtrl on Windows 2008 Server R2, including the required version of the Visual C++ distribution? I need to know what version of NagEvLogCtr to use (1.9.2?), whether or not to copy over the nagevlog.exe and NagEvLogCtrl.exe supplied with EventLog-64bit, where to put those files (if required), etc.
Thanks.
PJ
Re: NagEvLogCtrl Installation - Windows 2008 Server R2
Post by slansing »
You should be able to use the version in the documentation just fine, it should also prompt you if any other software packages are required during the MSI installer:
http://assets.nagios.com/downloads/nagi ... entLog.pdf
ranjitw
Post by ranjitw »
The http://assets.nagios.com/downloads/addo ... -1.9.2.exe executable is not working on windows 2008 server . Can you please suggest right executable for Windows server?
Regards,
Ranjit W
Can you elaborate on this? What is the error that you are getting?
ranjitw
Post by ranjitw »
Hi ,
When I try to install nagevlog-setup-1.9.2 on Windows 2008 R2 Service Pack 1 server its failing showing below error :
Regards,
Ranjit W
This is a known issue. When you try to install NagEventLog on a 64-bit machine, you would get 2 or 3 error messages. However, it would still work (or at least it worked for me when I was testing it). Keep clicking on "OK" button until the errors disappear. Let me know if this helped.
ranjitw
Post by ranjitw »
As suggested I kept on clikcing "OK" button until the error disappeared.
After the installation is completed I have clicked " Configure eventLog Agent " icon for which I got the below error . Please suggest the way to overcome this issue and get eventlog monitoring enabled.
Regards,
Ranjit W
This worked for me on Windows 7 64-bit. I haven't tested it on Windows 2008 Server R2. Unfortunately, the "NagEventLog" is a 3rd party software. It is not developed/maintained by us (Nagios). I found an old post in which Steve Shipway (the developer of NagEventLog) touches on the subject:
http://www.steveshipway.org/forum/viewt ... =22&t=1681
At this point, you have a few options as I see it:
1. Contact the developer and see if he's got a solution
2. Use NSClient++
3. Use Nagios Log Server
Hope this helps.
ranjitw
Post by ranjitw »
Hi ,
Can you please explain on how to configure real time event log monitoring using NSclient++ ?
Regards,
Ranjit W
WillemDH
Post by WillemDH »
Check out this article I wrote => http://outsideit.net/real-time-eventlog-monitoring/
Let me know if something is missing.
Nagios XI 5.8.1
https://outsideit.net
