Hey Guys,
Whats the best way to tail a log, look for something specific all the time and send it to SNMP OR have it as an alert?
Tail Log and Grep for XYZ show on SNMP
Re: Tail Log and Grep for XYZ show on SNMP
Start with the nagios exchange. There are a number of log related plugins for string checking, regex matching etc:
http://exchange.nagios.org/index.php?op ... =check_log
Reporting through snmp might require a custom solution.
Well the thing is the logs are on a remote server, and i want to tail it real time. i would need to have this custom tail log program / snmp run on that server and display via snmp
sreinhardt
- -fno-stack-protector
If you can, nsca would likely be a good option for this. Otherwise I think this is a bit out of scope for what we would handle as you'd likely be looking at a very specific snmp server.
well the reason i ask is b/c of for example the check_yum right? It checks the yum updates and checks for security updates and warns via snmp to a service created in nagios.
so how could i do the same for something i want to tail in a log? no?
ah like using extend + yum to check security updates
Something like this
http://community.zenoss.org/docs/DOC-2477
BUT i have no clue where to even start with that script.
We had a speaker, Robert Bolton, at last years conference go over this very topic, you can see his presentation slides and additional files here
http://www.nagios.com/events/nagiosworl ... sentations
Look for
"Custom SNMP OID Creation for System Monitoring"
Also the first 10 minutes are on youtube
http://www.youtube.com/watch?v=1JeI9kM5RgA
Look for
