How can i fix this....
I can't restart my nagios with:
service nagios restart or /etc/init.d/nagios restart
I can start it with ...
/usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
How can i fix it ..that i can restart back with the short service commando
i lost my nagios service
Re: i lost my nagios service
make a file named nagios in /etc/init.d
and add the following contents
#!/bin/sh
# chkconfig: 345 99 01
# description: Nagios network monitor
# File : nagios
# Author : Jorge Sanchez Aymar ([email protected])
# Changelog :
# 1999-07-09 Karl DeBisschop <[email protected]>
# - setup for autoconf
# - add reload function
# 1999-08-06 Ethan Galstad <[email protected]>
# - Added configuration info for use with RedHat's chkconfig tool
# per Fran Boon's suggestion
# 1999-08-13 Jim Popovitch <[email protected]>
# - added variable for nagios/var directory
# - cd into nagios/var directory before creating tmp files on startup
# 1999-08-16 Ethan Galstad <[email protected]>
# - Added test for rc.d directory as suggested by Karl DeBisschop
# 2000-07-23 Karl DeBisschop <[email protected]>
# - Clean out redhat macros and other dependencies
# 2003-01-11 Ethan Galstad <[email protected]>
# - Updated su syntax (Gary Miller)
# Description: Starts and stops the Nagios monitor
# used to provide network services status.
### BEGIN INIT INFO
# Provides: nagios
# Required-Start: $local_fs $syslog $network +ndo2db
# Default-Start:
# Default-Stop:
# Short-Description: start and stop nagios daemon
# Description: nagios
### END INIT INFO
status_nagios ()
if test -x $NagiosCGI/daemonchk.cgi; then
if $NagiosCGI/daemonchk.cgi -l $NagiosRunFile; then
return 0
else
return 1
fi
else
if ps -p $NagiosPID > /dev/null 2>&1; then
return 0
else
return 1
fi
fi
return 1
printstatus_nagios()
if status_nagios $1 $2; then
echo "nagios (pid $NagiosPID) is running..."
else
echo "nagios is not running"
fi
killproc_nagios ()
echo $2
kill $2 $NagiosPID
pid_nagios ()
if test ! -f $NagiosRunFile; then
echo "No lock file found in $NagiosRunFile"
exit 1
fi
NagiosPID=`head -n 1 $NagiosRunFile`
# Source function library
# Solaris doesn't have an rc.d directory, so do a test first
if [ -f /etc/rc.d/init.d/functions ]; then
. /etc/rc.d/init.d/functions
elif [ -f /etc/init.d/functions ]; then
. /etc/init.d/functions
fi
prefix=/usr/local/nagios
exec_prefix=${prefix}
NagiosBin=${exec_prefix}/bin/nagios
NagiosCfgFile=${prefix}/etc/nagios.cfg
NagiosStatusFile=${prefix}/var/status.dat
NagiosRetentionFile=${prefix}/var/retention.dat
NagiosCommandFile=${prefix}/var/rw/nagios.cmd
NagiosVarDir=${prefix}/var
NagiosRunFile=${prefix}/var/nagios.lock
#NagiosLockDir=/var/lock/subsys
NagiosLockDir=/usr/local/nagiosxi/var/subsys
NagiosLockFile=nagios
NagiosCGIDir=${exec_prefix}/sbin
NagiosUser=nagios
NagiosGroup=nagios
# Check that nagios exists.
if [ ! -f $NagiosBin ]; then
echo "Executable file $NagiosBin not found. Exiting."
exit 1
fi
# Check that nagios.cfg exists.
if [ ! -f $NagiosCfgFile ]; then
echo "Configuration file $NagiosCfgFile not found. Exiting."
exit 1
fi
# See how we were called.
case "$1" in
start)
echo -n "Starting nagios:"
$NagiosBin -v $NagiosCfgFile > /dev/null 2>&1;
if [ $? -eq 0 ]; then
# THESE TWO LINES WERE ADDED TO WORK WITH SUDO
touch $NagiosVarDir/nagios.log $NagiosRetentionFile
chown $NagiosUser $NagiosVarDir/nagios.log $NagiosRetentionFile
# su - $NagiosUser -c "touch $NagiosVarDir/nagios.log $NagiosRetentionFile"
rm -f $NagiosCommandFile
touch $NagiosRunFile
chown $NagiosUser:$NagiosGroup $NagiosRunFile
$NagiosBin -d $NagiosCfgFile
if [ -d $NagiosLockDir ]; then
touch $NagiosLockDir/$NagiosLockFile;
chown $NagiosUser:$NagiosGroup $NagiosLockDir/$NagiosLockFile;
fi
echo " done."
exit 0
else
echo "CONFIG ERROR! Start aborted. Check your Nagios configuration."
exit 1
fi
stop)
echo -n "Stopping nagios: "
pid_nagios
killproc_nagios nagios
# now we have to wait for nagios to exit and remove its
# own NagiosRunFile, otherwise a following "start" could
# happen, and then the exiting nagios will remove the
# new NagiosRunFile, allowing multiple nagios daemons
# to (sooner or later) run - John Sellens
#echo -n 'Waiting for nagios to exit .'
for i in 1 2 3 4 5 6 7 8 9 10; do
if status_nagios > /dev/null; then
echo -n '.'
sleep 1
else
break
fi
done
echo ''
echo 'Warning - nagios did not exit in a timely manner'
else
# Forcefully kill all other nagios processes that might be running, so we don't end up with a wierd setup
# Get a list of PIDs for all running Nagios daemons
plist=`ps axuw | grep "/usr/local/nagios/bin/nagios -d" | awk '{print $2}'`
#echo "PIDS"
#echo $plist
for pid in $plist; do
#echo "KILL $pid"
kill -9 $pid > /dev/null 2>&1
done
echo 'done.'
fi
rm -f $NagiosStatusFile $NagiosRunFile $NagiosLockDir/$NagiosLockFile $NagiosCommandFile
status)
pid_nagios
printstatus_nagios nagios
checkconfig)
printf "Running configuration check..."
echo " OK."
else
echo " CONFIG ERROR! Check your Nagios configuration."
exit 1
fi
restart)
echo "done."
$0 stop
$0 start
else
echo " CONFIG ERROR! Restart aborted. Check your Nagios configuration."
exit 1
fi
reload|force-reload)
echo "done."
$0 start
else
pid_nagios
printf "Reloading nagios configuration..."
killproc_nagios nagios -HUP
echo "done"
else
$0 stop
$0 start
fi
fi
else
echo " CONFIG ERROR! Reload aborted. Check your Nagios configuration."
exit 1
fi
echo "Usage: nagios {start|stop|restart|reload|force-reload|status|checkconfig}"
exit 1
esac
# End of this script
