Hello;
I want to use check_snmp_storage.pl to detect my remote linux server but I got the following error when I issue the command "perl ./check_snmp_storage.pl -H 192.168.0.100 -C public -m zzzz -w 80 -c 81 -v
error msg is...
Can't locate Net/SNMP.pm in @INC (@INC contains: /usr/local/lib/perl5 /usr/local/share/perl5 / usr/lib/perl5/vendor_perl....) at ./check_snmp_storage.pl line 15
But, I can find my SNMP.pm file in /usr/lib/perl5/vendor_perl folder.
I used the check_snmp -H 192.168.0.100 -C public -o sysUpTimeInstance to detect my remote linux server, and I receive the response like "SNMP OK -" which mean the communication is fine.
Can some one let me know what's wrong.
Cannot run check_snmp_storage.pl
Re: Cannot run check_snmp_storage.pl
perl -MCPAN -e shell
install Net::SNMP-
NagiosNewbis
Hi;
After install those components, I can run the check_snmp_storage.pl from the command line but how can I put it into my linux.cfg file for Nagios?
use local-service
host_name myLinux
service_description Check space usage
check_command check_snmp_storage
command_line check_snmp_storage.pl -H 192.168.30.17 -C public -$ -m ALL -w 70% -c 80%
When I run the verify command, I got this error
Error: Invalid service object directive 'command_line'.
Error: Could not add object property in file '/usr/local/nagios/etc/objects/linux.cfg' on line 125.
use local-service
host_name myLinux
NagiosNewbis
I got it up and running after I modified my commands.cfg and the linux.cfg files.
I added the following command to the commands.cfg file
# check host storage
command_name check_snmp_storage
command_line /usr/bin/perl -w $USER1$/check_snmp_storage.pl -H $HOSTADDRESS$ -C public -m -w 70% -c 80%
and remove the command_line syntax in the linux.cfg file in define service {...} section.
Now, my result showing this in my Nagios Core web interface, I want to monitor my /home only.
Virtual memory: 60%used(7036MB/11649MB) Swap space: 1%used(54MB/3888MB) /dev/shm: 0%used(0MB/3880MB) Memory buffers: 4%used(276MB/7761MB) Physical memory: 90%used(6983MB/7761MB) /boot: 8%used(36MB/484MB) Cached memory: 100%used(512MB/512MB) /home: 61%used(74552MB/121668MB) /: 4%used(2227MB/50397MB) (>80%) : CRITICAL
NagiosNewbis
If I want to monitor the usage of entire sda3, what command should be used?
You should be posting this in either Nagios Core and Nagios XI forums, depending on your flavor.
Nicholas Scott
