Hi im pretty new to using nagios xi, i installed nagios xi on a RHEL server based on the manual installation pdf.
I created a linux user named 'nagios' without a password, but the ./fullinstall script apparently does everything including also creating a linux user called 'nagios' for me. what i probably missed from the logs are the passwords for the created user 'nagios'. Now i cant seem to su into the user since i dont know the password for it. Does anyone know what the default values for this?
This is the pdf i used
https://www.google.com.my/url?sa=t&rct= ... 0616,d.bmk
autocreated linux user nagios' password
Re: autocreated linux user nagios' password
There is no password set for user nagios by default. You will not be able to su to nagios unless you are root. Please do not set a password on the user.
dividezero
So starting and stopping nagios services should be done as root rather than nagios user?
Yes. The nagios user should be treated as a system account, primarily for providing group/user permissions for most of nagios/XI.
