Error while using NRPE
MSPk
Post by MSPk »
Hi Team,
I'm trying to monitoring a RHEL server using nagios. I have already installed the NRPE agent on the target machine. When I try to monitor the parameters using nagios i see a message saying "Couldn't complete SSL handshake". Please suggest
Re: Error while using NRPE
There are a few different causes of this, though the most likely one is that the Nagios server's ip address is not defined in the remote host's nrpe.cfg file. Edit the nrpe.cfg file on the remote host and look for the line: allowed_hosts=127.0.0.1 You will need to add the ip address of your Nagios server to this line (it is comma-separated).
vi /usr/local/nagios/etc/nrpe.cfg
Change:
To:
allowed_hosts=127.0.0.1,<nagios server ip>
If you use xinetd for controlling the NRPE daemon (most people do), then you need to add the Nagios server's ip address to the xinetd nrpe configuration file: /etc/xinetd.d/nrpe. In this file you will find the line: only_from = 127.0.0.1 This list is space-delimited.
vi /etc/xinetd.d/nrpe
The other common cause is that NRPE was not compiled with ssl enabled. To recompile NRPE with ssl support, browse to your NRPE source directory (usually in /tmp/nrpe-2.14 if you followed the compiling NRPE from source document) and compile with the switch:
./configure --enable-ssl
cd /tmp/nrpe-2.14
make all
make install
Change:
To:
only_from = 127.0.0.1 <Nagios server ip>
If you use xinetd:
service xinetd restart
If you use an init-script method (this is the default way, but your distribution may vary):
/etc/init.d/nrpe restart
MSPk
Post by MSPk »
I have added the nagios server ip address in the nrpe.cfg and i already see the Ip address of the nagios server on the xinetd.d/nrpe. However I cant run the commands 'service xinetd restart' or '/etc/init.d/nrpe restart'. I get a messaging ' -bash: Service: command not found'
abrist
Red Shirt
Post by abrist »
How was nrpe installed? From source, repo, or from the XI agent download?
MSPk
Post by MSPk »
I have downloaded it from link on the nagios xi
Post by slansing »
Are you re-installing NRPE now?.. Your new thread suggests so.
MSPk
Post by MSPk »
Well, I have tried installing the same package on another server and that failed. they are 2 different issues. This Issue is something i faced ona server where the NRPE package has been installed successfully.
Can you try re-installing the linux agent following the steps, outlined in this document?
MSPk
Post by MSPk »
this exactly how we have installed this agent, but i dont midn re-installing it...!!!
Do you suggest we uninstall the current NRPE package before re-installing it or just install it over the current installation.
You can just install over.
