NRPE agent installation failure
MSPk
Post by MSPk »
HI Team,
I have tried to install nrpe on a linux server but it has failed with the following message.
install.log
yancy
Re: NRPE agent installation failure
Post by yancy »
MSPK,
Are you able to complete a
 yum update
-Yancy
MSPk
Post by MSPk »
I have chked with my linux admin and he has suggested not to run the update.
He has also suggested that the server has the required glidc files (glibc-2.5-81.el5_8.4)
rpm -qa | grep glibc
compat-glibc-2.3.4-2.26
glibc-2.5-107
compat-glibc-headers-2.3.4-2.26
glibc-devel-2.5-81.el5_8.4
glibc-common-2.5-81.el5_8.4
glibc-common-2.5-107
glibc-devel-2.5-107
glibc-headers-2.5-81.el5_8.4
glibc-headers-2.5-107
He has also suggested that we could install below if required
glibc.x86_64 2.5-107.el5_9.4 rhel-x86_64-server-5
glibc-common.x86_64 2.5-107.el5_9.4 rhel-x86_64-server-5
glibc-devel.x86_64 2.5-107.el5_9.4 rhel-x86_64-server-5
glibc-headers.x86_64 2.5-107.el5_9.4 rhel-x86_64-server-5
the version of linux we are using is - Red Hat Enterprise Linux Server release 5.9 (Tikanga) - 2.6.18-348.1.1.el5 #1 SMP Fri Dec 14 05:25:59 EST 2012 x86_64 x86_64 x86_64 GNU/Linux
yancy
Post by yancy »
MSPk,
Are you able to run package cleanup as suggested?
 You could try using --skip-broken to work around the problem
 You could try running: package-cleanup --problems
                        package-cleanup --dupes
                        rpm -Va --nofiles --nodigest
The program package-cleanup is found in the yum-utils package.
-Yancy
MSPk
Post by MSPk »
should the command be ./fullinstall --skip-broken??
yancy
Post by yancy »
MSPk,
Try cleaning any dependency problems:
if you receive command not found, you may need to run the following first
yum install yum-utils
-Yancy
MSPk
Post by MSPk »
We are now able to install the agent on the server. This thread can be closed.
yancy
Post by yancy »
MSPk,
Thanks for letting us know.
-Yancy
