Send mail notifications
alexmati
Post by alexmati »
Hi to all,
I 'm new to nagios and ubuntu so please be gently to me :)
I have install ubuntu on a VM and Nagios® Core™ Version 3.4.4.
I have add two hosts and everything works fine.
What i want is to Nagios can send mail notification if an error occurs.
I have read a lot of articles and says that i have to install postfix and mailx. Is this right.
FYI: I have a windows exchange server, so i don't want to install mail server to ubuntu machine. What i want is Nagios can use the existing mail server to send notifications.
Thanks you.
abrist
Red Shirt
Re: Send mail notifications
Post by abrist »
You will still need an mta to forward the mail to your exchange server. See: http://www.telnetport25.com/2012/02/con ... gios-core/
alexmati
Post by alexmati »
Hi again,
I have install postfix and mailx from the link you gave me.
I think the mail server is working because when i run telnet from this link (http://www.linux.com/component/content/ ... ail-server) i have the same results.
When i send custom notification from nagios i don't receive any mail.
FYI: 1) I haven't join the nagios server to domain.
2) Exchange server in configured to allow to send as anonymous
Maybe the solution is easy but i am a newby to ubuntu and nagios.
Thank you
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Did you also configure your exchange server to have a receive connector specific to nagios or allow nagios' IP on the existing one access to send to the server? Is the exchange server configured for anonymous smtp connections? Are you sending to the same domain as the exchange server or is it different?
alexmati
Post by alexmati »
Hi sreinhardt,
I allow nagios IP to send to the server.
Exchange server configured for anonymous smtp connections.
I am sending to the same domain where the exchange server is but as i told you before, nagios server is not joined into domain.
Thank you
Edit: i see this in mail.log
May 21 15:36:54 SAVSGATH01AP09 postfix/error[29695]: 16329221903: to=<*******.********@******.***>, relay=none, delay=216068, delays=216068/0.01/0/0, dsn=4.4.1, status=deferred (delivery temporarily suspended: connect to ****.*********.***[IP***.**.***.***]:25: Connection timed out)
The name and the IP of the server used in mail.log is through an external mail server and blocks it the firewall.
I miss something in order to send directly into domain?
Here is my main.cf configuration:
myhostname = ubuntu_server_name
alias_maps = hash:/etc/aliases
alias_database = hash:/etc/aliases
myorigin = /etc/mailname
mydestination = mymailserver.mydomain.net, nagios.notify-gr, ubuntu_server_name, localhost.localdomain, localhost
relayhost =
mynetworks = 127.0.0.0/8 [::ffff:127.0.0.0]/104 [::1]/128
mydomain = mydomain.net
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
sreinhardt
Maybe I missed this before, but you have a firewall in between that is blocking the connection on port 25? If that is the case, this port needs to get opened, or it doesn't matter how much configuration on either nagios or exchange is done, it will never work.
This is perfectly fine and normal, I just wanted to be sure they were the same name as exchange servers by default will not relay to another domain to prevent spam and generally will not even take in the message if it is not for their internal known domains. The nagios server does not need to be connected to it at all.
Can you telnet or nmap the smtp port from your nagios machine?
telnet [IP of exchange server]:25
nmap [IP of exchange server] -p 25
abrist
Red Shirt
Post by abrist »
Just for clarity's sake: the emails are being routed externally, correct? While you need them to remain internal? Do the fqdn server names in your "destination" directive resolve to external ip addresses? If they do, they will be routed externally. Does your exchange server have an internal name/address?
alexmati
Post by alexmati »
@sreinhardt: Firewall blocks on port 25 because nagios tries to send mails through external mail address and i don't want this. I am at the same network with exchange server, i can ping and telnet to IP but not the name of the exchange server.
@abrist: Yes, i need them to remain internal. I have the name of the server.
As i explain to sreinhardt, when i ping to the name of the server i have a result: ping: unknown host
What i am missing?
Edit: Maybe this is useful: When i install postfix, i have install it as Internet Site. Is this tight or not?
Thanks for your interesting guys
Edit 2: Finally works: :D
relayhost = My_Exchange_IP
mynetworks = ***.***.***.***/24
