Hi All,
I would like to configure a dependacy service for another service. below is my configuration and it is not working properly. Please suggest am I missing anything?
command_name Site1_Status
command_line $USER1$/check_http -I 172.20.32.35 -u http://sample1.example.com
command_name HTTP_Status
command_line $USER1$/check_http -H 172.20.32.35
host_name Station1
service_description website_status
check_command Site1_Status
host_name Station1
service_description HTTP Status
check_command HTTP_Status
define servicedependency{
host_name Station1
dependent_host_name Station1
dependent_service_description HTTP Status
Here if I stop httpd service then the Nagios should not check for website_status. This is my intension. Please suggest.
Thanks & Regards
Kalyan Pasupuleti
Dependancy service definition
Re: Dependancy service definition
Hi kalyan1709,
Just to confirm, the service_description is the service which is being depended on (master service), whereas dependent_service_description is the dependent service.
Also, you might need to use "execution_failure_criteria". This defines when the dependent service is actively checked (i.e. setting the value as c means don't check the dependent service when the master service is critical).
Below is an example configuration you can use:
So whilst the service "Load" on "host1" is in an OK state, it won't actively check the service "MySQL Load" on "host1".
You can adjust this as required for your set up.
Good luck!
Kind Regards,
Gary Shergill
dependent_host_name host1
dependent_service_description MySQL Load
host_name host1
service_description Load
execution_failure_criteria o
Good luck!
Kind Regards,
Gary Shergill
Let us know how this works out for you kalyan1709! And thanks again Gshergill!
kalyan1709
Hi Gary,
Thank you very much. I followed your procedure and it is working fine for me.
Thanks & Regards
Kalyan Pasupuleti
Thanks & Regards
Kalyan Pasupuleti
Hi Kalyan,
No problem, glad to hear it's working.
Kind Regards,
Gary Shergill
Kind Regards,
Gary Shergill
