I think the Core Config Should be move outside the config menu. because it is confusing as to which screen you are in.
Atleast add a bread crumb or highlight the menu option you are in. You can very easily get lost in the UI. because everything looks the same.
Need to improve the UI menu options
Re: Need to improve the UI menu options
Thank you for this idea, we have talked about certain UI changes in the future, would you be interested in adding a feature request to our tracking site?:
http://tracker.nagios.com/
That would be awesome, you can cite this thread in the message body there as well.
