when I create a query based monitor using the MSsQL query wizard. query would not run and on inspection I found that there were extra characters embeded in the query string.
here is an example
check_xi_mssql_query!--username xxxx --password "xxxx" --database master --query "SELECT+COUNT%28%2A%29+FROM+sys.sysperfinfo" --result "Expected result" --decode --warning 50 --critical 200
MS SQL Wizard having extra characters in query string
Re: MS SQL Wizard having extra characters in query string
Can you show us what the string "should" look like? Do you have a screenshot of the service's CCM page in CCM > Services > "Service Name" or can you copy the service definition from:
Please remove any security related information.
/usr/local/nagios/etc/services/"servicename".cfgRe: MS SQL Wizard having extra characters in query string
This is the view from CCM services edit view.
--username xxx--password "xxxx" --database master --query "SELECT+COUNT%28%2A%29+FROM+sys.sysperfinfo" --result "Expected result" --decode --warning 50 --critical 200
the query should look like
select count(*) from sys.sysperinfo
Below is the file view
host_name xxxxx
service_description MSSQL Query - SampleQuery
use xiwizard_mssqlquery_service
check_command check_xi_mssql_query!--username xxxx --password xxxxx --database master --query "SELECT+COUNT%28%2A%29+FROM+sys.sysperfinfo" --result "Expected result" --decode --warning 50 --critical 200
max_check_attempts 5
check_interval 5
retry_interval 1
notification_interval 60
contacts nagiosadmin
_xiwizard mssqlquery
register 1
host_name xxxxx
check_interval 5
retry_interval 1
register 1
What version of XI are you running?
Nagios XI 2012R1.6
First of all, that version of XI may have an issue with url encoding in the ccm, I suggest you upgrade to 2012r2.0. Afterwards, try fixing the check $ARGn$ and let us know if the problem still persists.
we are on a trial version of xi, will upgrade work on that?
You should be able to download the tarball, and install it as per our upgrade instructions, you trial will still expire on the same day:
http://assets.nagios.com/downloads/nagi ... ctions.pdf
