Migration Problems (32 to 64bit)
Due to extreme slowness in our initial NagiosXI system (started with a 32bit only VMware version in 2010), even with extensive resources (8 CPU cores, 16gig RAM), we are attempting to move this to a 64bit install (RHEL 6.4 x86_64
We have ensured that the original system is running the latest release 2012r2.0, and ran the backup_xi script. We then installed NagiosXI using the source tarball on the new server (also 2012r2.0), and ran the restore_xi script.
Once that was done we followed the extra steps to ensure that the 64bit binaries were properly there (remove the installed.subcomponents file in /tmp/nagiosxi, run A-subcomponents, then build-perms-bin, as outlined in the backup/restore documentation).
We then ran the script provided in the FAQ to migrate the perf data from 32bit to 64bit using rrdtool dump and rrdtool restore commands (outlined here: http://support.nagios.com/wiki/index.ph ... Install.3F)
At this time, we can log into our new NagiosXI install, and as we use AD integration, our AD credentials work properly. Where we run into a problem is if we try to apply any changes.
Most of the time, it will return an error, and says to look at the snapshot file for errors, however, there is no recent snapshot file to review. What also happens is that it will just sit there trying to verify, without ending.
We also have tested the "Write Config Files". What happens with this is that we just get a blank frame. No completion notice, no failures, nothing. Running the Verify Config from there returns Duplicate Warnings (existing install does the same), but no errors.
I have run "reconfigure_nagios.sh &> reconfig.txt" and will include the output here.
I am also including the output from "tail -f /usr/local/nagiosxi/var/cmdsubsys.log &> cmd.txt", however, cmdsubsys.log (and thus cmd.txt) is not returning much of anything, as the last few runs, Apply Configuration is just sitting there.
We *HAD* a paid support/maintenance contract, however, our Operations dept. failed to renew. This is in process now, and we should be back on the paid support shortly.
Re: Migration Problems (32 to 64bit)
Run the following command and show the output:
ll /usr/local/nagiosxi/scriptsBe sure to check out our Knowledgebase for helpful articles and solutions!
[root@colnagiosxi-new perfdata]# ll /usr/local/nagiosxi/scripts
total 436
-rwxr-x---. 1 apache nagios 2899 May 23 08:41 backup_xi.sh
-rw-r--r--. 1 root root 2620 May 23 09:51 cmd.txt
-rwxr-x---. 1 apache nagios 649 May 23 08:41 export_nagiosql.sh
-rwxr-x---. 1 apache nagios 1017 Nov 8 2011 fixperms.sh
-rwxr-x---. 1 apache nagios 821 May 23 08:41 handle_nagioscore_event.php
-rwxr-x---. 1 apache nagios 829 May 23 08:41 handle_nagioscore_notification.php
-rwxr-x---. 1 apache nagios 429 May 23 08:41 import_nagiosql.sh
-rwxr-x---. 1 apache nagios 149 May 23 08:41 kill_rrdtool.sh
-rwxr-x---. 1 apache nagios 272372 May 23 08:41 nagiosql_defaults.sql
-rwxr-x---. 1 apache nagios 970 May 23 08:41 nagiosql_delete_contact.php
-rwxr-x---. 1 apache nagios 2010 May 23 08:41 nagiosql_delete_host.php
-rwxr-x---. 1 apache nagios 505 May 23 08:41 nagiosql_delete_object.sh
-rwxr-x---. 1 apache nagios 3118 May 23 08:41 nagiosql_delete_service.php
-rwxr-x---. 1 apache nagios 993 May 23 08:41 nagiosql_delete_timeperiod.php
-rwxr-x---. 1 apache nagios 1637 May 23 08:41 nagiosql_exportall.php
-rwxr-x---. 1 apache nagios 1323 May 23 08:41 nagiosql_importall.php
-rwxr-x---. 1 apache nagios 1847 May 23 08:41 nagiosql_login.php
-rwxr-x---. 1 apache nagios 2246 May 23 08:41 nagiosql_snapshot.sh
-rwxr-x---. 1 apache nagios 258 May 23 08:41 nagiosql_trim_backups.sh
-rwxr-x---. 1 apache nagios 515 May 23 08:41 nom_create_nagioscore_checkpoint_cond.sh
-rwxr-x---. 1 apache nagios 826 May 23 08:41 nom_create_nagioscore_checkpoint.sh
-rwxr-x---. 1 apache nagios 632 May 23 08:41 nom_create_nagioscore_errorpoint.sh
-rwxr-x---. 1 apache nagios 784 May 23 08:41 nom_restore_nagioscore_checkpoint.sh
-rwxr-x---. 1 apache nagios 839 May 23 08:41 nom_restore_nagioscore_checkpoint_specific.sh
-rwxr-x---. 1 apache nagios 2972 May 23 08:41 nom_trim_nagioscore_checkpoints.sh
-rwxr-x---. 1 apache nagios 4592 May 23 08:41 parse_core_eventlog.php
-rwxr-x---. 1 apache nagios 6074 May 23 08:41 patch_ndoutils.php
-rw-r--r--. 1 apache nagios 2634 May 23 08:48 reconfig.txt
-rwxr-x---. 1 apache nagios 597 May 23 08:41 reconfigure_nagios.sh
-rwxr-x---. 1 apache nagios 1037 May 23 08:41 repairmysql.sh
-rwxr-xr-x. 1 apache nagios 6846 May 23 08:41 reset_config_perms
-rwxr-x---. 1 apache nagios 280 May 23 08:41 reset_config_perms.c
-rwxr-xr-x. 1 apache nagios 1187 May 23 08:41 reset_config_perms.sh
-rwxr-x---. 1 apache nagios 1155 May 23 08:41 reset_nagiosadmin_password.php
-rwxr-x---. 1 apache nagios 964 May 23 08:41 restart_nagios_with_export.sh
-rwxr-x---. 1 apache nagios 765 May 23 08:41 restore_defaults.sh
-rwxr-x---. 1 apache nagios 5342 May 23 08:41 restore_xi.sh
-rwxr-x---. 1 apache nagios 1847 May 23 08:41 send_to_auditlog.php
-rw-r-----. 1 apache nagios 2379 May 23 08:41 uninstall_xi.sh-
sreinhardt
- -fno-stack-protector
You are definitely going to want to run "chown -R nagios.nagios /usr/local/nagiosxi/scripts/"
While we're at it please send back the following:
ll /usr/local/nagiosxi/var
ll /usr/local/nagios/var
ll /usr/local/nagios/var/rwNagios-Plugins maintainer exclusively, unless you have other C language bugs with open-source nagios projects, then I am happy to help! Please pm or use other communication to alert me to issues as I no longer track the forum.
sreinhardt wrote:You are definitely going to want to run "chown -R nagios.nagios /usr/local/nagiosxi/scripts/"
While we're at it please send back the following:Code: Select all
ll /usr/local/nagiosxi/var ll /usr/local/nagios/var ll /usr/local/nagios/var/rw
[root@colnagiosxi-new etc]# ll /usr/local/nagiosxi/var
total 624
-rw-r--r--. 1 apache nagios 303 May 23 08:45 cleaner.log
-rw-r--r--. 1 apache nagios 303 May 19 04:03 cleaner.log.1
-rw-r--r--. 1 apache nagios 303 May 12 04:02 cleaner.log.2
-rw-r--r--. 1 apache nagios 302 May 5 04:02 cleaner.log.3
-rw-r--r--. 1 apache nagios 302 Apr 28 04:02 cleaner.log.4
-rw-r--r--. 1 apache nagios 2863 May 23 08:46 cmdsubsys.log
-rw-r--r--. 1 apache nagios 22 May 19 04:04 cmdsubsys.log.1
-rw-r--r--. 1 apache nagios 22 May 12 04:03 cmdsubsys.log.2
-rw-r--r--. 1 apache nagios 22 May 5 04:03 cmdsubsys.log.3
-rw-r--r--. 1 apache nagios 22 Apr 28 04:03 cmdsubsys.log.4
drwsrwsr-x. 2 apache nagios 4096 Jan 30 13:05 components
-rw-r--r--. 1 apache nagios 8 May 22 19:56 corelog.data
-rw-r--r--. 1 apache nagios 19297 May 22 19:56 corelog.diff
-rwxrwxr-x. 1 nagios nagios 3014 May 17 09:48 corelog.newobjects
-rw-r--r--. 1 apache nagios 2677 May 23 08:45 dbmaint.log
-rw-r--r--. 1 apache nagios 2677 May 19 04:00 dbmaint.log.1
-rw-r--r--. 1 apache nagios 2677 May 12 04:00 dbmaint.log.2
-rw-r--r--. 1 apache nagios 2677 May 5 04:00 dbmaint.log.3
-rw-r--r--. 1 apache nagios 2677 Apr 28 04:00 dbmaint.log.4
-rw-r--r--. 1 apache nagios 21 May 23 08:45 deadpool.log
-rw-r--r--. 1 apache nagios 21 May 19 04:00 deadpool.log.1
-rw-r--r--. 1 apache nagios 21 May 12 04:00 deadpool.log.2
-rw-r--r--. 1 apache nagios 21 May 5 04:00 deadpool.log.3
-rw-r--r--. 1 apache nagios 21 Apr 28 04:00 deadpool.log.4
-rw-r--r--. 1 apache nagios 23831 May 23 08:46 eventman.log
-rw-r--r--. 1 apache nagios 4099 May 19 04:04 eventman.log.1
-rw-r--r--. 1 apache nagios 20 May 12 04:03 eventman.log.2
-rw-r--r--. 1 apache nagios 20 May 5 04:03 eventman.log.3
-rw-r--r--. 1 apache nagios 2154 Apr 28 04:03 eventman.log.4
-rw-r--r--. 1 apache nagios 18 May 23 08:45 feedproc.log
-rw-r--r--. 1 apache nagios 25 May 19 04:04 feedproc.log.1
-rw-r--r--. 1 apache nagios 25 May 12 04:03 feedproc.log.2
-rw-r--r--. 1 apache nagios 25 May 5 04:03 feedproc.log.3
-rw-r--r--. 1 apache nagios 25 Apr 28 04:03 feedproc.log.4
-rw-r--r--. 1 apache nagios 0 May 19 04:03 load_url.log
-rw-r--r--. 1 apache nagios 824 May 18 01:32 load_url.log.1
-rw-r--r--. 1 apache nagios 826 May 13 11:25 load_url.log.2
-rw-r--r--. 1 apache nagios 802 Mar 20 14:03 load_url.log.3
-rw-r--r--. 1 apache nagios 827 Mar 18 18:16 load_url.log.4
-rw-r--r--. 1 apache nagios 0 May 23 08:45 nom.log
-rw-r--r--. 1 apache nagios 567 May 23 08:46 perfdataproc.log
-rw-r--r--. 1 apache nagios 324 May 19 04:04 perfdataproc.log.1
-rw-r--r--. 1 apache nagios 243 May 12 04:03 perfdataproc.log.2
-rw-r--r--. 1 apache nagios 243 May 5 04:03 perfdataproc.log.3
-rw-r--r--. 1 apache nagios 243 Apr 28 04:03 perfdataproc.log.4
-rw-r--r--. 1 apache nagios 31616 May 22 17:01 recurringdowntime.log
-rw-r--r--. 1 apache nagios 242202 May 19 04:01 recurringdowntime.log.1
-rw-r--r--. 1 apache nagios 31155 May 12 04:01 recurringdowntime.log.2
-rw-r--r--. 1 apache nagios 31144 May 5 04:01 recurringdowntime.log.3
-rw-r--r--. 1 apache nagios 31145 Apr 28 04:01 recurringdowntime.log.4
-rw-r--r--. 1 apache nagios 0 May 23 08:45 reportengine.log
-rw-r--r--. 1 apache nagios 28 Apr 15 2012 reportengine.log.1
-rw-r--r--. 1 apache nagios 28 Apr 8 2012 reportengine.log.2
-rw-r--r--. 1 apache nagios 28 Apr 1 2012 reportengine.log.3
-rw-r--r--. 1 apache nagios 28 Mar 25 2012 reportengine.log.4
drwxr-xr-x. 2 apache nagios 4096 May 24 08:49 subsys
-rw-r--r--. 1 apache nagios 8153 May 23 08:46 sysstat.log
-rw-r--r--. 1 apache nagios 272 May 19 04:04 sysstat.log.1
-rw-r--r--. 1 apache nagios 272 May 12 04:03 sysstat.log.2
-rw-r--r--. 1 apache nagios 275 May 5 04:03 sysstat.log.3
-rw-r--r--. 1 apache nagios 275 Apr 28 04:03 sysstat.log.4
-rw-r--r--. 1 apache nagios 790 May 23 08:41 xi-sys.cfg
-rwxr-xr-x. 1 apache nagios 202 May 23 08:41 xiversion
[root@colnagiosxi-new etc]# ll /usr/local/nagios/var
total 475768
drwxrwxr-x. 2 apache nagios 36864 May 24 00:00 archives
-rwxrwxr-x. 1 apache nagios 10291698 May 13 12:24 graphapi.log
-rw-rw-r--. 1 apache nagios 17753092 May 24 10:47 host-perfdata
-rw-r--r--. 1 nagios nagios 6 May 24 08:49 nagios.lock
-rw-rw-r--. 1 nagios nagios 1516672 May 24 10:47 nagios.log
-rwxrwxr-x. 1 apache nagios 698522 Oct 24 2011 nagios.log.old
-rw-r--r--. 1 apache nagios 5 May 22 19:48 ndo2db.lock
srwxr-xr-x. 1 apache nagios 0 May 22 19:48 ndo.sock
-rw-r--r--. 1 apache nagios 1788503 May 22 17:01 npcd.log
-rw-r--r--. 1 apache nagios 10485888 May 22 17:01 npcd.log.old
-rw-rw-r--. 1 apache nagios 4780183 May 24 08:49 objects.cache
-rw-rw-r--. 1 apache nagios 1222397 Oct 31 2011 objects.precache
-rw-rw-rw-. 1 apache nagios 1264434 May 22 16:17 perfdata.log
-rw-rw-rw-. 1 apache nagios 2743 Oct 12 2011 perfdata.log.old
-rw-------. 1 nagios nagios 7508093 May 24 09:49 retention.dat
drwxrwsr-x. 2 apache nagios 4096 May 24 08:49 rw
-rw-rw-r--. 1 apache nagios 422304510 May 24 10:47 service-perfdata
drwxrwxr-x. 5 apache nagios 4096 Jan 26 2011 spool
drwxrwxr-x. 2 apache nagios 4096 May 22 17:01 stats
-rw-rw-r--. 1 nagios nagios 7469606 May 24 10:47 status.dat
[root@colnagiosxi-new etc]# ll /usr/local/nagios/var/rw
total 0
prw-rw----. 1 nagios nagios 0 May 24 08:49 nagios.cmd
Let's try running the following commands first:
Then run:
Do "reconfigure" completes successfully now or fails?
chown root.nagios /usr/local/nagiosxi/scripts/reset_config_perms
chown root.nagios /usr/local/nagiosxi/scripts/reset_config_perms.shCode: Select all
cd /usr/local/nagiosxi/scripts/
./reset_config_perms.sh
./reconfigure_nagios.shBe sure to check out our Knowledgebase for helpful articles and solutions!
The reconfigure_nagios.sh seemed to complete, however, when clicking "Apply Configuration", it's still sitting and processing for an extended period of time (well over 5 minutes at this time)
Command submitted for processing...
Waiting for configuration verification............................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................
Can you post the output of the following after you start the apply configuration:
What did you migrate over? You should have only needed to provision a new server/vm, then run through the import config documentation, and move additional data over "if the data is supported for migration." Nothing revolving around these directories or scripts permissions should have ever been changed during this process..
tail -20 tail /var/log/mysqld.logRe: Migration Problems (32 to 64bit)
130523 9:09:16 InnoDB: Completed initialization of buffer pool
130523 9:09:16 InnoDB: Started; log sequence number 0 44233
130523 9:09:16 [Note] Event Scheduler: Loaded 0 events
130523 9:09:16 [Note] /usr/libexec/mysqld: ready for connections.
Version: '5.1.69' socket: '/var/lib/mysql/mysql.sock' port: 3306 Source distribution
130523 9:56:13 [Note] /usr/libexec/mysqld: Normal shutdown
130523 9:56:13 [Note] Event Scheduler: Purging the queue. 0 events
130523 9:56:15 InnoDB: Starting shutdown...
130523 9:56:19 InnoDB: Shutdown completed; log sequence number 0 44233
130523 9:56:19 [Note] /usr/libexec/mysqld: Shutdown complete
130523 09:56:19 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended
130523 14:57:44 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
130523 14:57:44 InnoDB: Initializing buffer pool, size = 8.0M
130523 14:57:44 InnoDB: Completed initialization of buffer pool
130523 14:57:44 InnoDB: Started; log sequence number 0 44233
130523 14:57:44 [Note] Event Scheduler: Loaded 0 events
130523 14:57:44 [Note] /usr/libexec/mysqld: ready for connections.
Once that was complete, I followed the directions on the Backup/Restore PDF, which said to remove /tmp/nagiosxi/installed.subcomponents, and then run "/tmp/nagiosxi/A-subcomponents" followed by "/tmp/nagiosxi/build-perms-bin".
After that, I ran the rrdtool script to export the 32bit RRDs to xml, moved them over to the new machine, and ran rrdtool to import the XMLs back in as rrd.
The only difference between the two systems is one CentOS 5.9 32bit, and the new one is RedHat Enterprise 6.4 x86_64.
Is crond running on the new system?
ps -ef |grep cmdsubsys
