upgrade hiccup
benhank
upgrade hiccup
Post by benhank »
Hey guys!
I am doing the upgrade to 2012 r2 and I am getting this:
PHP Warning:  PHP Startup: Unable to load dynamic library '/usr/lib64/php/modules/module.so' - /usr/lib64/php/modules/module.so: cannot open shared object file: No such file or directory in Unknown on line 0
PHP Fatal error:  SourceGuardian Incompatible loader version. This protected script has been encoded with newer version of SourceGuardian. Please download and install the <A HREF="http://www.sourceguardian.com/ixeds/">latest loaders</A>. Error code [19] in /usr/local/nagiosxi/html/includes/dbl.inc.php on line 2
can you guys help do what the message suggests?
Proudly running:
Nagios Network Analyser
Nagios Fusion
Re: upgrade hiccup
Post by slansing »
This should have been fixed in the latest install/upgrade scripts, this should get you around this issue:
modify:
 /etc/php.d/mcrypt.ini
extension=module.so
TO:
 extension=mcrypt.so
benhank
Re: upgrade hiccup
Post by benhank »
# /etc/php.d/mcrypt.ini
-bash: /etc/php.d/mcrypt.ini: Permission denied
[root@LkennagiosT01 ~]# ]# /etc/php.d/mcrypt.ini
Proudly running:
Nagios Fusion
abrist
Red Shirt
Re: upgrade hiccup
Post by abrist »
You got to edit the file good sir!
nano /etc/php.d/mcrypt.ini
Change the line:
extension=module.so
To:
extension=mcrypt.so
and then save out with Ctrl-o to save and the Ctrl-x to exit!
Restart apache:
service apache restart
Cheers!
benhank
Re: upgrade hiccup
Post by benhank »
Hey thanks for Nano, it is waaaayy better than VI.
I did what you said,
; Enable mcrypt extension module
extension=mcrypt.so
but the issue persists. (we both knew the easy fixes wasn't gonna work on my haunted systems). ti make it worse
apache: unrecognized service
Proudly running:
Nagios Fusion
Re: upgrade hiccup
Post by slansing »
Try:
service httpd restart
benhank
Re: upgrade hiccup
Post by benhank »
i did the service restarted but the problem still pops up.
Proudly running:
Nagios Fusion
Re: upgrade hiccup
Post by slansing »
Please run through the following, this should get us passed the bug:
cd /tmp
rm -rf nagiosxi xi*
wget http://assets.nagios.com/downloads/nagiosxi/xi-2012-devel.tar.gz
tar xzf xi*.tar.gz
cd /tmp/nagiosxi
./upgrade
benhank
Re: upgrade hiccup
Post by benhank »
perfect as usual. all set man!
Proudly running:
Nagios Fusion
abrist
Red Shirt
Re: upgrade hiccup
Post by abrist »
benhank wrote:Hey thanks for Nano, it is waaaayy better than VI.
All hail vim!
Locking her up.
