Notifications Page takes a long time to open
MSPk
Post by MSPk »
We are using Nagios XI 2012R1.8 and have configured about 64 hosts with 640 services. When I try to open the notification page it take about 5-10 mins to open up and during this time it will not allow me to open section on nagios either. everything else works fine, please suggest.
Re: Notifications Page takes a long time to open
Post by slansing »
Can you do the following:
Navigate to Admin > System Profile > click the "Download" button
Then in the file that is downloaded please remove sensitive information, such as your config snapshot "It should be the .tar.gz file within the zip you downloaded. And make sure the logs that were gathered do not show sensitive info. Then upload the information here in attachments. That will allow us to check some system vitals.
MSPk
Post by MSPk »
here it is...
Profile
profile.zip
What kind of browser are you using? Are you seeing the same behavior when you try a different browser? Run the following commands and show the output:
tail /var/log/httpd/error_log
tail /var/log/messages
MSPk
Post by MSPk »
We are using IE8 and unfortunately dont have any other brower in our environment to test.
check_mssql_server.py: error: Cannot specify both instance and port.
which: no gnome-session in (/sbin:/usr/sbin:/bin:/usr/bin)
[Thu May 23 13:30:40 2013] [error] [client 122.98.112.104] PHP Notice:  Undefined index:  contactgroup_members in /usr/local/nagiosxi/html/includes/components/ccm/classes/Form_class.php on line 585, referer: http://209.207.236.210/nagiosxi//includes/components/ccm/?cmd=view&type=contact
[Thu May 23 13:58:02 2013] [error] [client 122.98.112.104] PHP Notice:  Undefined index:  contactgroup_members in /usr/local/nagiosxi/html/includes/components/ccm/classes/Form_class.php on line 585, referer: http://209.207.236.210/nagiosxi//includes/components/ccm/?cmd=view&type=contact
[Thu May 23 13:58:10 2013] [error] [client 122.98.112.104] PHP Notice:  Undefined index:  contactgroup_members in /usr/local/nagiosxi/html/includes/components/ccm/classes/Form_class.php on line 585, referer: http://209.207.236.210/nagiosxi//includes/components/ccm/index.php?cmd=view&type=contact
[Thu May 23 13:58:18 2013] [error] [client 122.98.112.104] PHP Notice:  Undefined index:  contactgroup_members in /usr/local/nagiosxi/html/includes/components/ccm/classes/Form_class.php on line 585, referer: http://209.207.236.210/nagiosxi//includes/components/ccm/index.php?cmd=view&type=contact
May 24 01:01:13 lfvses19030 nagios: SERVICE ALERT: NEODEVWS1-MySQL;MySQL Table Cache Hit Rate;OK;HARD;5;OK - table cache hitrate 0.11%, 70.31% filled
May 24 01:01:13 lfvses19030 nagios: SERVICE NOTIFICATION: nagiosadmin;NEODEVWS1-MySQL;MySQL Table Cache Hit Rate;OK;xi_service_notification_handler;OK - table cache hitrate 0.11%, 70.31% filled
May 24 01:01:13 lfvses19030 nagios: SERVICE NOTIFICATION: Service Now;NEODEVWS1-MySQL;MySQL Table Cache Hit Rate;OK;xi_service_notification_handler;OK - table cache hitrate 0.11%, 70.31% filled
May 24 01:01:14 lfvses19030 nagios: SERVICE NOTIFICATION: test;NEODEVWS1-MySQL;MySQL Table Cache Hit Rate;OK;xi_service_notification_handler;OK - table cache hitrate 0.11%, 70.31% filled
May 24 01:02:13 lfvses19030 nagios: Warning: Return code of 139 for check of service 'Drive E: Disk Usage' on host 'NEODSTGNET01' was out of bounds.
May 24 01:03:23 lfvses19030 nagios: Warning: Return code of 139 for check of service 'Drive E: Disk Usage' on host 'NEODSTGNET02' was out of bounds.
May 24 01:03:23 lfvses19030 nagios: SERVICE ALERT: NEOTSTGWSD02-MySQL;MySQL Table Cache Hit Rate;OK;HARD;5;OK - table cache hitrate 0.01%, 53.12% filled
May 24 01:03:23 lfvses19030 nagios: SERVICE NOTIFICATION: nagiosadmin;NEOTSTGWSD02-MySQL;MySQL Table Cache Hit Rate;OK;xi_service_notification_handler;OK - table cache hitrate 0.01%, 53.12% filled
May 24 01:03:23 lfvses19030 nagios: SERVICE NOTIFICATION: Service Now;NEOTSTGWSD02-MySQL;MySQL Table Cache Hit Rate;OK;xi_service_notification_handler;OK - table cache hitrate 0.01%, 53.12% filled
May 24 01:03:24 lfvses19030 nagios: SERVICE NOTIFICATION: test;NEOTSTGWSD02-MySQL;MySQL Table Cache Hit Rate;OK;xi_service_notification_handler;OK - table cache hitrate 0.01%, 53.12% filled
MSPk
Post by MSPk »
I have managed to check it on a mozilla firefox 3 browser and even there it is the same.
Post by slansing »
Please run the following and share the output with us:
service nagios stop
killall -9 nagios
service ndo2db stop
service httpd stop
service httpd start
service ndo2db start
service nagios start
It also looks like you are having issues with npcd hitting your load threshold which we can fix after we figure out this current problem. Can you share the specs of this server with us? Such as Memory, CPU, HDD, etc.
MSPk
Post by MSPk »
This is the output I get.
service nagios stop
Stopping nagios: done.
[root@localhost ~]# killall -9 nagios
nagios: no process killed
[root@localhost ~]# service ndo2db stop
Stopping ndo2db: head: cannot open `/usr/local/nagios/var/ndo2db.lock' for reading: No such file or directory
done.
[root@localhost~]# service httpd stop
Stopping httpd:                                            [  OK  ]
You have mail in /var/spool/mail/root
[root@localhost ~]# service httpd start
Starting httpd: httpd: Could not reliably determine the server's fully qualified domain name, using 209.207.236.210 for ServerName
                                                           [  OK  ]
[root@localhost ~]# service ndo2db start
Starting ndo2db: done.
[root@NEOTPRDNGOS01 ~]# service nagios start
Starting nagios: done.
MSPk
Post by MSPk »
Server Configuration:
Red Hat Enterprise Linux 5 -Virtual Server
Processor Qty: 2,
Processor Speed: 2.66 GHz,
Total Memory: 8GB,
HD Capacity: 128GB, HD Config: "/"46 GB + "/apps"64GB
MSPk
Post by MSPk »
does the above output suggest any issue with the server/notification view?
