Setting up Install Process
Resolving Dependencies
--> Running transaction check
---> Package php-ldap.x86_64 0:5.3.3-3.el6_2.8 will be installed
--> Processing Dependency: php-common = 5.3.3-3.el6_2.8 for package: php-ldap-5.3.3-3.el6_2.8.x86_64
Error: Package: php-ldap-5.3.3-3.el6_2.8.x86_64 (base)
Requires: php-common = 5.3.3-3.el6_2.8
Installed: php-common-5.3.3-14.el6_3.x86_64 (@updates)
php-common = 5.3.3-14.el6_3
Available: php-common-5.3.3-3.el6_2.8.x86_64 (base)
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
[root@pxdc001apnag1 run]#
It seems PHP-LDAP requires an older version of php-common. I really do not want to downgrade my PHP-COMMON version. Is there another way to getting PHP-LDAP to work?
EDIT: I already tried running --skip-broken AND rpm -Va --nofiles --nodigest to no effect
My Nagios Version: Nagios XI 2012R1.6 | CENTOS 6.3 64 Bit
Interesting, most likely this is an issue from varying repos. Can you run the following command and send it back please. This will give us a list of the installed php packages and what yum is seeing as available.
rpm -qa | grep php
yum list php php-common php-ldap
So updates repo is causing issues due to ldap needing the base version of php-common. Lets try a downgrade of php, this may cause some issues with other php packages but that should be all, and we can definitely work through that.
No the only difference is the update repo trying to use versions newer than base dependencies. However, yum is smart enough to realize that php-ldap and potentially others require the older version and will not update unless dependencies allow it. As far as I know there should not be any major security issues, base tends to quickly backport anything important.
