i have a HP DL380 Gen8 Servers and i want to monitor the Servers hardware.
The Server have an ILO4 Management Board.
Which plugin can i use to monitor the Servers Hardware via the ILO4 Board ?
how to monitor HP ILO4
Re: how to monitor HP ILO4
I have not come across a plugin that will do it for you. You may be able to write a perl script to login and scrap the status.
The easierst way is to setup a snmp trap on the nagios server and get the ILO to feed data to it.
http://nagios.sourceforge.net/docs/3_0/ ... ptrap.html
There was one I found on the exchange. Check the comments as there was a suggested change to the script to work with v4 of the management interface:
http://exchange.nagios.org/directory/Pl ... lo/details
