i need a way to check a routers link has more then 1M passing through it.
I have used check_rrdtraf to alert on the upper thresholds, how do i check for lower thresholds?
router check_rrdtraf check there is more then 1M of traffic
Re: router check_rrdtraf check there is more then 1M of traf
How do you have the command defined within the service configuration file? Can you post your service config file blocking out any sensitive information?
