Notification error
sarfarosh
Notification error
Post by sarfarosh »
Hello Guys,
I am not able to get proper Notification through Mail if any alerts it triggered , the notification that i get looks like
    Sent: Tuesday, May 28, 2013 9:59 AM
    To:
    Subject: PROBLEM Service Alert - BHIL-4-ASIFNG-HASAN-202.14/$ is $
    ***** Nagios XI Alert *****
    Nagios has detected a problem with this service.
    Notification Type: PROBLEM
    Service: $
    Host: BHIL-4-ASIFNG-HASAN-202.14
    Address: 172.16.202.14
    State: $
    Info:
    Date/Time: 2013-05-28 09:59:07
    Respond: http://123.176.37.155/nagiosxi//rr.php?uid=49--1-ecf775975c7dd5ebe7959e1305445e49
    Nagios URL: http://123.176.37.155/nagiosxi/
Mine templet in notification management is
Host Alert Message:
%alertsummary%
Notification Type: %type%
Host: %host%
State: %hoststate%
Address: %hostaddress%
Info: %hostoutput%
Date/Time: %datetime%
Respond: %responseurl%
Nagios URL: %xiserverurl%
Service Alert Message:
%alertsummary%
Service: %service%
Host: %host%
State: %servicestate%
Info:
%serviceoutput%
abrist
Red Shirt
Re: Notification error
Post by abrist »
What handlers do you have set for the contact in question?
Go to --> configure --> core config manager --> contacts --> click the contact in the question --> click alert settings tab.
What commands are selected for each of the: "Manage host notification commands" and "Manage service notification commands" ?
sarfarosh
Post by sarfarosh »
Abrist
Below are the Handler command assigned to the Contact in alert setting for service Notification
notify-host-by-email
notify-service-by-email
process-host-perfdata-file-pnp-bulk
process-host-perfdata-pnp-normal
process-service-perfdata-file-bulk
process-service-perfdata-file-pnp-bulk
process-service-perfdata-pnp-normal
xi_host_event_handler
xi_host_notification_handler
xi_service_event_handler
xi_service_notification_handler
Now only available command is
check_none
abrist
Red Shirt
Post by abrist »
This probably your issue. The contact should only have 1 notification command, and you are most likely receiving these '$' emails from setting a service handler on for a host command and vice versa.
For "manage host notification commands", only set:
For "manage service notification commands", only set:
Remove the others, save, and then "apply configuration".
