How to monitor MySQL in Nagios with enabled networking.....
imran_khan
Hello All,
I have installed and configured NRPE agent on Linux box (Server A) and configured all the services in Nagios system and its working fine expect MySQL database service, it showing error “Can't connect to MySQL server on 'Server A' (111)” in Nagios monitor system (Server B). I have already added user and grant the Nagios server host to that user. Please find the details for the same.
NRPE file setting (Server A):-
[email protected] [~]# cat /etc/nagios/nrpe.cfg
allowed_hosts=127.0.0.1, Server B IP Address
command[check_mysql]=/usr/lib64/nagios/plugins/check_mysql -H localhost -u xyz -p user_password
Database user:-
| xyz | *844736F9FFBEFB8FB25ED19 | Server B IP Address
In the MySQL configuration file of (Server A) networking is enabled for security purpose but I want to monitor MySQL database service without removing/disabling networking (skip- networking) option from configuration file. How can I do, please suggest me.
Database user:-
Reason: Please do not double post. We see everyones threads and get to them as soon as possible.
Re: How to monitor MySQL in Nagios with enabled networking..
Have you tried running the check from the cli (on the remote host running the mysql db)?
/usr/lib64/nagios/plugins/check_mysql -H localhost -u xyz -p user_passwordFormer Nagios employee
imran_khan
This command is working fine on remote database server. Please find the details for the same.
Uptime: 3200215 Threads: 5 Questions: 661109334 Slow queries: 68665 Opens: 39224251 Flush tables: 1 Open tables: 64 Queries per second avg: 206.582
sreinhardt
- -fno-stack-protector
Great to see that the local check is working, can you now show us what your check_nrpe command looks like on the nagios server side of things?
Does you password or username include any nasty meta chars? (#,%,!,@,etc?)
Lets try the check from the Nagios Server now:
/usr/lib64/nagios/plugins/check_nrpe -H <server A ip> -c check_mysqlFormer Nagios employee
imran_khan
Getting below error.
[[email protected]]# /usr/lib64/nagios/plugins/check_nrpe -H <Server A IP> -c check_mysql
CHECK_NRPE: Socket timeout after 10 seconds.
imran_khan
Other command is working fine except check_mysql.
[[email protected]]# /usr/lib64/nagios/plugins/check_nrpe -H 69.64.43.172 -c check_ssh
SSH OK - OpenSSH_5.3 (protocol 2.0) | time=0.006040s;;;0.000000;10.000000
[[email protected]]# /usr/lib64/nagios/plugins/check_nrpe -H 69.64.43.172 -c check_load
OK - load average: 7.09, 6.31, 7.48|load1=7.090;30.000;40.000;0; load5=6.310;25.000;35.000;0; load15=7.480;20.000;31.000;0;
[[email protected]]# /usr/lib64/nagios/plugins/check_nrpe -H 69.64.43.172 -c check_swap
SWAP OK - 86% free (1755 MB out of 2047 MB) |swap=1755MB;409;204;0;2047
When you run it locally, how long does the check take to run? Have you looked over the nrpe common solutions document for the socket timeout error?
http://assets.nagios.com/downloads/nagi ... utions.pdf
imran_khan
Within seconds get reply. Not getting socket error with other command except check_mysql.
Also, check permissions on the remote host:
ls -la /usr/lib64/nagios/pluginsFormer Nagios employee
