Is there any information on monitoring systems that obtain their IP addresses by DHCP?
I am trying to find if you can identify them by other means (eg MAC, name or something else)
so if a machine moves arond it is recognised as a single instance.
I am fairly new to network montoring so I might just be searching for the wrong keywords, or
it may not be something that is possible...
Monathan
Monitoring client systems with dynamic (dhcp) addresses
Re: Monitoring client systems with dynamic (dhcp) addresses
Please see the following post:
http://support.nagios.com/knowledgebase ... wdesc=true
We need to mainly look at this section:
That's the big one there, as long as the above is true for your environment you should be fine.you can add anything you want for a host address. You can specify an IP address, MAC address, GPS coordinates, etc. Nagios does not directly interpret a host's address (or addresses), so you can do pretty much anything you want. Nagios simply passes this address to plugins and external commands via the $HOSTADDRESS$ macro. You'll have to make sure that you host check command (and possibly service checks, etc.) can understand the format of your host's address in order to check it though.
