Hello Team,
I am new to Nagios and i have just install in my network. i am already added my AD and montroing CPU/memory and disk space..
i want to important Services running in Active directory and my WEB Servers..
Could any one help me with configuration steps?
Prashant
How to Monitor Windows AD important services using NAGIOS?
Re: How to Monitor Windows AD important services using NAGIO
Are you running nagios core or nagios xi?
hello,
Thanks for your Reply.i am running nagios Core..Please see below screen capture --
Prashant
Prashant
sreinhardt
- -fno-stack-protector
If the service names are listed in services.msc or by running a "net use" on the local system you can use the service name to monitor via the client(I presume) that you have installed on the windows machine. Otherwise if you are using something like wmi checks you can also query service information in a variety of ways. How are you presently getting the machines cpu and such data?
prashant,
Can you be more specific about what "services" you want to import?
Are you looking to monitor services on the Windows Server responsible for running Active Directory?
-Yancy
-Yancy
thanks for your reply..yes i want to monitor services running on windows responsible for Active Directory. i just added below service configuration:-
host_name TW-WEB
service_description AeLookupSvc
check_command check_nt!SERVICESTATE!-d SHOWALL -l "AeLookupSvc"
but i dont see this service being displayed in Nagios dashboard. any clue? if i am following correct configuration or not?
Prashant
host_name TW-WEB
Prashant
As far as I can tell there is nothing inherently wrong with the configuration you've provided, did you remember to restart the nagios service to apply the changes? You can test your configuration by running the command: /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
As far as Active Directory monitoring goes the important ADC services are as follows (from memory):
win2k3: Netlogon,NtFrs,kdc,W32Time,DNS,ISMSERV
win2k8: NTDS,kdc,W32Time,DNS,NtFrs,IsmServ
win2k12: NTDS,ADWS,kdc,W32Time,DNS,NtFrs,IsmServ
Some of these services may not be required in your environment (I.e. DNS if your ADC's don't serve DNS) and some additional services may be required (I.e. DHCP or Wins). AD is one of those products that is a composition of different components and you sort of just have to vet it a little bit to work out which ones are relevant to you.
@OP - Let us know how jsmurphy's suggestions worked out for you. . .
