Windows Performance Counter - No Graph
Pilly170
Post by Pilly170 »
I'm having issues with getting a graph to display any data.
I can run the command via the CLI
Works ok.
I then create a new service for the server
Arg3 = -l "\\TCPv4\Connections Established","Connections are %.2f %%"
then the graph is blank
Any ideas what I did wrong
Re: Windows Performance Counter - No Graph
Post by slansing »
Lets start by adding an additional slash:
\\TCPv4\\Connections Established
Save, apply config, wait for a few checks to go through "Or force them through the interface." Then check the graphs, also, what is listed in the Advanced tab or the service details page under Performance Data?
Pilly170
Post by Pilly170 »
You are a star. Thank you.
How would you write
\\PhysicalDisk(4 G:)\Disk Writes/sec ???
This should do it:
"\\PhysicalDisk(4 G:)\\Disk Writes/sec"
