We are perfoming two url checks from nagios.These uRl require authentication to login to the site.
Somehow nagios is not able perform checks properly for these two url's.Where as i can use the same command for other urls with authentication which is working .
Below ar ethe URL's
https://learningqa.corp.xerox.com/en-US ... gPage.aspx
https://portalqa.thehub.xerox.com/en-us ... epage.aspx
Credentials
[redacted]
Nagios command:
-bash-3.2$ ./check_http --ssl -c 100 -t 100 -f follow -H portalqa.thehub.xerox.com -u /_layouts/error.aspx -a [redacted]
HTTP WARNING: HTTP/1.1 401 Unauthorized
problem with url check authentication
Reason: Don't post credentials on the forums! They are now [redacted] !
Re: problem with url check authentication
Open a ticket at [email protected] if you need us to perform tests with sensitive information.
