Notifications not being issued
rks
Post by rks »
I am running Nagios XI on RHEL5.
I have enabled notifications globally.
## /usr/local/nagios/etc/nagios.cfg
enable_notifications=1
I have enabled notifications for my device and service template:
# /usr/local/nagios/etc/static/templates/host.cfg
define host {
       name                                     ctv-server
       use                                      linux-server
       contact_groups                           ctvadmins
       notifications_enabled                    1
       register                                 0
       name                                     ctv-service
       use                                      local-service
       register                                 0
I have configured the contacts with specific notifications:
define contact {
        contact_name                            ctvadmin
        alias                                   C TV Administrator
        host_notification_period                ctvadmin_notification_times
        service_notification_period             ctvadmin_notification_times
        host_notification_options               d,u,r,f,s
        service_notification_options            w,u,c,r,f,s
        host_notification_commands              notify-host-by-email
        service_notification_commands           notify-service-by-email
        email                                   [email protected]
        use                                     xi_contact_generic
define contactgroup {
        contactgroup_name                       ctvadmins
        alias                                   C TV Administrators
        members                                 ctvadmin
The test email from nagios XI console succeeds.
Yet, I do not see notifications issued when a host or a service goes down.
I see the following messages in /usr/local/nagios/var/nagios/log:
# tail -f /usr/local/nagios/var/nagios.log
[1370120018] SERVICE NOTIFICATION: ctvadmin;ctv-xjabprd-2;Jabber CM1;CRITICAL;notify-service-by-email;CRITICAL - Socket timeout after 10 seconds
which seems to indicate that the notification was initiated - I do not see the email in my inbox.
How do I troubleshoot this?
thanks
rks
Re: Notifications not being issued
Post by rks »
The "notification settings" page in Nagios XI says that the feature is only
available in the enterprise edition (I am running an eval version):
I assume this restriction applies only to the notification settings page of Nagios XI
and not to notifications themselves, which is a part of Nagios core.
pl help
thanks,
rks
Post by rks »
I notice in /var/log/maillog that
un  3 00:50:08 ctv-cache postfix/pickup[3307]: 38D08160D: uid=500 from=<nagios>
Jun  3 00:50:08 ctv-cache postfix/cleanup[16017]: 38D08160D: message-id=<[email protected]>
Jun  3 00:50:08 ctv-cache postfix/qmgr[1392]: 38D08160D: from=<[email protected]>, size=797, nrcpt=1 (queue active)
Jun  3 00:50:09 ctv-cache postfix/smtp[16026]: 38D08160D: to=<[email protected]>, relay=rcdn-mx-01.cisco.com[72.163.7.166]:25, delay=0.93, delays=0.02/0/0.83/0.08, dsn=5.0.0, status=bounced (host rcdn-mx-01.cisco.com[72.163.7.166] said: 553 Domain of sender address <[email protected]> does not resolve. (in reply to MAIL FROM command))
However, I have a valid settings in Admin -> Manage Email Settings:
Where does it obtain the email settings from?
thanks,
abrist
Red Shirt
Post by abrist »
rks wrote: Where does it obtain the email settings from?
XI send email through the phpmailer function. The settings are a combination of what you enter in the "manage email settings" page and the XI server's hostname.
rks wrote:Jun 3 00:50:09 ctv-cache postfix/smtp[16026]: 38D08160D: to=<[email protected]>, relay=rcdn-mx-01.cisco.com[72.163.7.166]:25, delay=0.93, delays=0.02/0/0.83/0.08, dsn=5.0.0, status=bounced (host rcdn-mx-01.cisco.com[72.163.7.166] said: 553 Domain of sender address <[email protected]> does not resolve. (in reply to MAIL FROM command))
This error message seems to imply that your nagios xi server is lacking an FQDN, and your smtp server requires it. Try changing your XI server's hostname to an FQDN, or talk to your email admin to have the restrictions loosened for mail coming from the XI server.
