Monitoring URLs
fao
Monitoring URLs
Post by fao »
Hello folks,
I'd like to start monitoring URLs with NagiosXI. Here is the case : we have several contexts under the same domain name (e.g. mydomain.com/context1, mydomain.com/context2, mydomain.com/context3,...). I wanted to make each of the contexts a separate host but this is not possible since the "/" is not accepted in the host name field. What would be the better approach to achieve this?
Re: Monitoring URLs
Post by slansing »
You could title them any way you wish, then add the address in the address field rather than the hostname field. That should work, or you could determine the true IP of these sites and use that as well.
