Hello everyone,
I downloaded a NSClient++ for one of my servers and its on the nagios website, but i am getting a "no data was received from host error". Does anyone know how to fix this? thanks in advance
No data was received from host!
Re: No data was received from host!
Hi ofadl,
Can you post the services.cfg and commands.cfg for the windows host being monitored?
Thank you.
Kind Regards,
Gary Shergill
Thank you.
Kind Regards,
Gary Shergill
the host is called VNADAT641
here is the host, and service definition
use generic-host ; Name of host template t$
host_name vnadat641
alias VNA Eq DB Warehouse
address 10.200.50.202
#######SERVICE DEFINITIONS#########
host_name VNAADM648,vnaidx122,vnadat641
service_description NSClient++ Version
check_command check_nt!CLIENTVERSION
and here is my commands file
# COMMANDS.CFG - SAMPLE COMMAND DEFINITIONS FOR NAGIOS
# NOTIFICATION COMMANDS
command_name notify-host-by-email
command_line /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" | /usr/bin/mail $
command_line /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\nHost: $HOSTALIAS$\nAddress: $HOSTADDRESS$\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nAdditi$
# HOST CHECK COMMANDS
# On Debian, check-host-alive is being defined from within the
# nagios-plugins-basic package
# PERFORMANCE DATA COMMANDS
# 'process-host-perfdata' command definition
command_name process-host-perfdata
command_line /usr/bin/printf "%b" "$LASTHOSTCHECK$\t$HOSTNAME$\t$HOSTSTATE$\t$HOSTATTEMPT$\t$HOSTSTATETYPE$\t$HOSTEXECUTIONTIME$\t$HOSTOUTPUT$\t$HOSTPERFDATA$\n" >> /var/lib/nagios3/host-perfdata.out
# 'process-service-perfdata' command definition
command_name process-service-perfdata
command_line /usr/bin/printf "%b" "$LASTSERVICECHECK$\t$HOSTNAME$\t$SERVICEDESC$\t$SERVICESTATE$\t$SERVICEATTEMPT$\t$SERVICESTATETYPE$\t$SERVICEEXECUTIONTIME$\t$SERVICELATENCY$\t$SERVICEOUTPUT$\t$SERVICEPERFDATA$\n" >> /var/l$
# 'check_equinox_http' command definition
command_name check_equinox_http
command_line $USER1$/is_url_alive "http://$HOSTADDRESS$$ARG1$" "$ARG2$" "$ARG3$" "$ARG4$"
thanks
host_name vnadat641
thanks
It does not look like you have the "check_nt" command defined in your commands.cfg file, you will need to define the command to use it. I'd recommend going through the following guide on setting this up:
http://nagios.sourceforge.net/docs/3_0/ ... ndows.html
im getting a duplicate definition error when i tried adding that to the commands file like so
Warning: Duplicate definition found for command 'check_nt' (config file '/etc/na gios3/objects/commands.cfg', starting on line 58)
Error: Could not add object property in file '/etc/nagios3/objects/commands.cfg' on line 60.
Okay, so you must have it, can you share the check_nt definition you have in your commands.cfg?
what i posted earlier was my entire commands file, then i tried adding that definition to it, and i get that duplicate error
Odd, are you sure that it is not reading an additional commands.cfg file? The above was from:
Correct?
