Hey Everyone,
I'm experiencing some weirdness on a particular host. About 3-4 times a day all NRPE checks on a particular host all of a sudden go critical.
I've gone in and restarted the NRPE daemon, but that doesn't seem to fix it.I don't see any weirdness regarding NRPE in /var/log/messages. Any thoughts?
NRPE checks randomly error out
Re: NRPE checks randomly error out
What is the error code that is returned when they go critical?
It'll say:
CHECK_NRPE: Socket timeout after 10 seconds.
What's funny is that the server isn't being taxed, and it never looses ping.
So this indicates that there could be a network related issue occurring then, either on the port forwarding and, or the actual connection, does your host go down at this time as well?? Either that, or something is keeping the check from returning it's data within 10 seconds, to test this, try adding a:
To the service definition after the $HOSTADDRESS$ or IP, this will increase the timeout, then verify the config, and see if you have this issue again.
-t 30Re: NRPE checks randomly error out
Well it turns out that the hard disk on my Hypervisor is going bad. The Hypervisor would randomly just eat up disk I/O and cause only the NRPE checks to error out, even though on the VM server itself, there was no load. Weird.
Anyhow. Thanks for all the help!
No problem, at least you were able to figure out what it was! Closing.
