I need to list the number of connections in ESTABLISHED state
attached to a tcp server port. I checked check_tcp but it does not
provide this option.
Is there a standard plugin that provides this function?
thanks,
Listing number of ESTABLISHED connections on a tcp port
Re: Listing number of ESTABLISHED connections on a tcp port
I do not believe there is a pre-packaged TCP plugin other than the one you used, you can take a look at this list to find the specific one you need:
http://exchange.nagios.org/index.php?op ... chword=tcp
