Suddenl y getting below error CRITICAL - Socket timeout afte
imran_khan
Post by imran_khan »
Suddenly getting below error. Sometimes I am getting response from the server.
[[email protected] plugins]# ./check_smtp xyz.com
CRITICAL - Socket timeout after 10 seconds
[root@ example.com plugins]# ./check_smtp xyz.com
SMTP OK - 8.218 sec. response time|time=8.218449s;;;0.000000
SMTP OK - 6.496 sec. response time|time=6.496059s;;;0.000000
SMTP OK - 6.530 sec. response time|time=6.529657s;;;0.000000
I am trying to run above command from Nagios server to smtp sever xyz.com.
Imran Khan.
abrist
Red Shirt
Re: Suddenl y getting below error CRITICAL - Socket timeout
Post by abrist »
Either you have packet loss issues, or the timeout is occasionally, not enough. Try increasing the timeout first:
./check_smtp xyz.com -t 20
-t, --timeout=INTEGER
Seconds before connection times out (default: 10)
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Well in all of the checks you have that passed, you are pushing above 60% of the default check time. It likely would help to bump that up a bit with the timeout flag. Try something like this:
./check_smtp -H xyz.com -t 30 -w 10 -c 20
This will set an overall timeout of 30 seconds, with warning at 10 and critical at 20.
