Bandwidth usage
wiproltdwiv
Bandwidth usage
Post by wiproltdwiv »
hi,
In Nagios xi there is an option in reports - > bandwidth usage.
but while generating this report we find only blank screen . please find the attachment for the same.
pls suggest.
details
verison : Nagios XI 2012R2.1
abrist
Red Shirt
Re: Bandwidth usage
Post by abrist »
If you look at the upper right corner of the image, you will notice that you only have 3 green checks instead of six. How many red dots do you have on the Home --> Process info page?
wiproltdwiv
Re: Bandwidth usage
pls find the screenshot
Re: Bandwidth usage
Post by slansing »
Can you run the following, and then open the bandwidth usage report and send us the output of the command?:
tail -f /var/log/httpd/error_log
And again with:
tail -f /var/log/httpd/access_log
Do you have enterprise edition?
wiproltdwiv
Re: Bandwidth usage
we dont have enterprise edition.
pls find the attached screen shot for your ref
wiproltdwiv
Re: Bandwidth usage
httpd error log
abrist
Red Shirt
Re: Bandwidth usage
Post by abrist »
Lets see what is on that line, run the following command and post the output in code wraps:
head -360  /usr/local/nagiosxi/html/includes/components/bandwidthreport/index.php | tail -20
wiproltdwiv
Re: Bandwidth usage
[root@EMSNagios1 ~]# head -360 /usr/local/nagiosxi/html/includes/components/ban dwidthreport/index.php | tail -20
<th><?php echo gettext("Action"); ?></th></tr>
</thead>
<tbody>
<?php
// sort names
arsort($legalnames);
$lastip="";
foreach($legalnames as $name)
parse_name($name,$ip,$port);
//XI MOD - adding host authorization
if(!isset($authIPs[$ip])) continue; //skip unauthorized hosts
//printf("<a href=\"%s?name=%s\">%s</a><br>\n", $_SERVER['SCRIPT _NAME'], $name, $name);
echo "<tr>";
$theip=$ip;
if($lastip==$ip) //still on the same host //XI MOD - added host name with IP for clarity
[root@EMSNagios1 ~]# ^C
abrist
Red Shirt
Re: Bandwidth usage
Post by abrist »
What web browser are you using? There have been issues with IE and jquery as of late, so if you are running IE, you may need to enable "compatibility mode". Try a different browser as well.
wiproltdwiv
Re: Bandwidth usage
we tried chrome also.. we are facing similar issue..
kindly suggest .
