add contact
oz123
add contact
Post by oz123 »
Can I add an additional contact to all of my services in a single action or easy way from the GUI instead of edit the files and import again ? I have 740 services.
for example, I want to add the "abcdefg" to all of my services contacts.
host_name Wordpress1
service_description / Disk Usage
use xiwizard_nrpe_service
check_command check_nrpe!check_disk!-a '-w 12% -c 10% -p /'!!!!!!
max_check_attempts 2
check_interval 5
retry_interval 1
notification_interval 60
first_notification_delay 0
notification_options w,c,u,r,f,s,
notifications_enabled 1
contacts nagiosadmin,abcdefg
_xiwizard linux-server
register 1
abrist
Red Shirt
Re: add contact
Post by abrist »
You can mass add contacts using the "bulk modifications" tool. You will find it at: Configure --> Tools --> Bulk modifications.
oz123
Re: add contact
Post by oz123 »
Needs enterprise license, I don't have it. anything else ?
Re: add contact
You can try Enterprise for free (full functionality) for 60 days and get the job done. This is going to be the easiest way.
oz123
Re: add contact
Post by oz123 »
I had it before, will it let me install again ?
abrist
Red Shirt
Re: add contact
Post by abrist »
If you have used your 60 day enterprise trial before, then you most likely cannot activate it again. Sorry.
