Installation step failed - b-installfusion
This support forum board is for questions relating to Nagios Fusion.
ssouthern
Post by ssouthern »
We're attempting to install Fusion in our environment in a virtual machine on Hyper-V 2012. We've installed CentOS 6.4 i386 in the VM, with 2 virtual CPU, 2GB RAM and a 40GB VHDX.
The documentation at http://assets.nagios.com/downloads/nagi ... ctions.pdf works fine until we run ./fullinstall.
It runs through and then outputs "INSTALLATION ERROR!" and "The script that failed was './B-installfusion'"
install.log's last lines read:
Reloading httpd:
Creating postgres database and user...
-bash: /root/nagiosfusion/nagiosfusion/create_postgres_db.sh: Permission denied
if I run create_postgres_db.sh directly, it outputs "psql: FATAL: database "root" does not exist"
What are the next steps?
Re: Installation step failed - b-installfusion
Run the following commands and show the output:
grep postgres /etc/group
grep postgres /etc/passwd
sestatus
ssouthern
Post by ssouthern »
Here's the output:
#grep postgres /etc/group
postgres:x:26:
#grep postgres /etc/passwd
postgres:x:26:26:PostgreSQL Server:/var/lib/pgsql:/bin/bash
#sestatus
SELinux status: enabled
SELinuxfs mount: /selinux
Current mode: permissive
Mode from config file: enforcing
Policy version: 24
Policy from config file: targeted
Any help is appreciated! Thanks!
abrist
Red Shirt
Post by abrist »
Are you running the fullinstall as user "root"? (you should be)
How permissive is your selinux "permissive" configuration? (sometimes clients need to fully disable it)
ssouthern
Post by ssouthern »
I am running it as root.
Per the note displayed by the fullinstall script, this is a very basic install of CentOS. We haven't done any configuration on the OS so far, other than the IP addressing, so SELinux would be default for CentOS 6.4 x86.
abrist
Red Shirt
Post by abrist »
Could you post the install.log in entirety (in code wrpas)?
ssouthern
Post by ssouthern »
I hope this is what you're looking for...
Nagios Fusion Installation Log
DATE: Mon Jun 17 16:24:25 EDT 2013
DISTRO INFO:
CentOS
6.4
i686
THIS IS A NEW INSTALL!
INSTALLING:
full=2012R1.5
major=2012
minor=R1.5
releasedate=2012-01-17
release=205
Configuring Yum...
centos-release-6-4.el6.centos.10.i686
Enabling RPMForge repo...
Installing RPMForge PKG: packages/rpmforge-release-0.5.2-2.el6.rf.i686.rpm
warning: packages/rpmforge-release-0.5.2-2.el6.rf.i686.rpm: Header V3 DSA/SHA1 Signature, key ID 6b8d79e6: NOKEY
Preparing...                ##################################################
rpmforge-release            ##################################################
Loaded plugins: fastestmirror, security
Determining fastest mirrors
 * base: less.cogeco.net
 * extras: less.cogeco.net
 * rpmforge: apt.sw.be
 * updates: centos.mirror.netelligent.ca
perl-Compress-Raw-Bzip2.i686               2.052-1.el6.rf               rpmforge
rpmforge-release.i686                      0.5.3-1.el6.rf               rpmforge
rpmforge-release RPM installed OK
Enabling EPEL repo...
Installing EPEL PKG: ./packages/epel-release-6-5.noarch.rpm
warning: ./packages/epel-release-6-5.noarch.rpm: Header V3 RSA/SHA256 Signature, key ID 0608b895: NOKEY
epel-release                ##################################################
Loading mirror speeds from cached hostfile
 * epel: archive.linux.duke.edu
epel-release.noarch                        6-8                          epel
epel-release RPM installed OK
Enabling CentOS 6 Continuous Release repo...
 * epel: mirrors.cat.pdx.edu
Setting up Install Process
Resolving Dependencies
--> Running transaction check
---> Package centos-release-cr.i686 10:6-0.el6.centos will be installed
Dependencies Resolved
 Package                 Arch       Version                  Repository    Size
Installing:
 centos-release-cr       i686       10:6-0.el6.centos        extras       3.9 k
Transaction Summary
Install       1 Package(s)
Total download size: 3.9 k
Installed size: 509
Downloading Packages:
Running rpm_check_debug
Running Transaction Test
Transaction Test Succeeded
Running Transaction
Warning: RPMDB altered outside of yum.
  Installing : 10:centos-release-cr-6-0.el6.centos.i686                     1/1
  Verifying  : 10:centos-release-cr-6-0.el6.centos.i686                     1/1
Installed:
Complete!
 * epel: mirrors.rit.edu
centos-release-cr RPM installed OK
Yum configured OK
Installing prerequisites...
 * epel: fedora.westmancom.com
Package dstat-0.7.0-1.el6.noarch already installed and latest version
Package unzip-6.0-1.el6.i686 already installed and latest version
Package 32:bind-utils-9.8.2-0.17.rc1.el6_4.4.i686 already installed and latest version
Package openssl-1.0.0-27.el6_4.2.i686 already installed and latest version
Package sysstat-9.0.4-20.el6.i686 already installed and latest version
---> Package gd.i686 0:2.0.35-11.el6 will be installed
--> Processing Dependency: libXpm.so.4 for package: gd-2.0.35-11.el6.i686
---> Package gd-devel.i686 0:2.0.35-11.el6 will be installed
--> Processing Dependency: zlib-devel for package: gd-devel-2.0.35-11.el6.i686
--> Processing Dependency: libpng-devel for package: gd-devel-2.0.35-11.el6.i686
--> Processing Dependency: libjpeg-devel for package: gd-devel-2.0.35-11.el6.i686
--> Processing Dependency: libXpm-devel for package: gd-devel-2.0.35-11.el6.i686
--> Processing Dependency: libX11-devel for package: gd-devel-2.0.35-11.el6.i686
--> Processing Dependency: freetype-devel for package: gd-devel-2.0.35-11.el6.i686
--> Processing Dependency: fontconfig-devel for package: gd-devel-2.0.35-11.el6.i686
---> Package httpd.i686 0:2.2.15-28.el6.centos will be installed
--> Processing Dependency: httpd-tools = 2.2.15-28.el6.centos for package: httpd-2.2.15-28.el6.centos.i686
--> Processing Dependency: libaprutil-1.so.0 for package: httpd-2.2.15-28.el6.centos.i686
--> Processing Dependency: libapr-1.so.0 for package: httpd-2.2.15-28.el6.centos.i686
--> Processing Dependency: apr-util-ldap for package: httpd-2.2.15-28.el6.centos.i686
---> Package openssl-devel.i686 0:1.0.0-27.el6_4.2 will be installed
--> Processing Dependency: krb5-devel for package: openssl-devel-1.0.0-27.el6_4.2.i686
---> Package php.i686 0:5.3.3-22.el6 will be installed
--> Processing Dependency: php-common(x86-32) = 5.3.3-22.el6 for package: php-5.3.3-22.el6.i686
--> Processing Dependency: php-cli(x86-32) = 5.3.3-22.el6 for package: php-5.3.3-22.el6.i686
---> Package php-gd.i686 0:5.3.3-22.el6 will be installed
---> Package php-odbc.i686 0:5.3.3-22.el6 will be installed
--> Processing Dependency: php-pdo(x86-32) for package: php-odbc-5.3.3-22.el6.i686
--> Processing Dependency: libodbc.so.2 for package: php-odbc-5.3.3-22.el6.i686
---> Package php-pear.noarch 1:1.9.4-4.el6 will be installed
---> Package php-pgsql.i686 0:5.3.3-22.el6 will be installed
---> Package php-tidy.i686 0:5.3.3-22.el6 will be installed
--> Processing Dependency: libtidy-0.99.so.0 for package: php-tidy-5.3.3-22.el6.i686
---> Package php-xml.i686 0:5.3.3-22.el6 will be installed
---> Package postgresql.i686 0:8.4.13-1.el6_3 will be installed
---> Package postgresql-devel.i686 0:8.4.13-1.el6_3 will be installed
---> Package postgresql-libs.i686 0:8.4.13-1.el6_3 will be installed
---> Package postgresql-server.i686 0:8.4.13-1.el6_3 will be installed
---> Package rpmdevtools.noarch 0:7.5-2.el6 will be installed
--> Processing Dependency: rpm-build >= 4.4.2.1 for package: rpmdevtools-7.5-2.el6.noarch
--> Processing Dependency: fakeroot for package: rpmdevtools-7.5-2.el6.noarch
---> Package rrdtool.i686 0:1.3.8-6.el6 will be installed
--> Processing Dependency: dejavu-sans-mono-fonts for package: rrdtool-1.3.8-6.el6.i686
--> Processing Dependency: dejavu-lgc-sans-mono-fonts for package: rrdtool-1.3.8-6.el6.i686
---> Package xinetd.i686 2:2.3.14-38.el6 will be installed
---> Package apr.i686 0:1.3.9-5.el6_2 will be installed
---> Package apr-util.i686 0:1.3.9-3.el6_0.1 will be installed
---> Package apr-util-ldap.i686 0:1.3.9-3.el6_0.1 will be installed
---> Package dejavu-lgc-sans-mono-fonts.noarch 0:2.30-2.el6 will be installed
---> Package dejavu-sans-mono-fonts.noarch 0:2.30-2.el6 will be installed
---> Package fakeroot.i686 0:1.12.2-22.2.el6 will be installed
--> Processing Dependency: fakeroot-libs = 1.12.2-22.2.el6 for package: fakeroot-1.12.2-22.2.el6.i686
---> Package fontconfig-devel.i686 0:2.8.0-3.el6 will be installed
---> Package freetype-devel.i686 0:2.3.11-14.el6_3.1 will be installed
---> Package httpd-tools.i686 0:2.2.15-28.el6.centos will be installed
---> Package krb5-devel.i686 0:1.10.3-10.el6_4.3 will be installed
--> Processing Dependency: libselinux-devel for package: krb5-devel-1.10.3-10.el6_4.3.i686
--> Processing Dependency: libcom_err-devel for package: krb5-devel-1.10.3-10.el6_4.3.i686
--> Processing Dependency: keyutils-libs-devel for package: krb5-devel-1.10.3-10.el6_4.3.i686
---> Package libX11-devel.i686 0:1.5.0-4.el6 will be installed
--> Processing Dependency: pkgconfig(xcb) >= 1.1.92 for package: libX11-devel-1.5.0-4.el6.i686
--> Processing Dependency: pkgconfig(xproto) for package: libX11-devel-1.5.0-4.el6.i686
--> Processing Dependency: pkgconfig(xcb) for package: libX11-devel-1.5.0-4.el6.i686
--> Processing Dependency: pkgconfig(kbproto) for package: libX11-devel-1.5.0-4.el6.i686
---> Package libXpm.i686 0:3.5.10-2.el6 will be installed
---> Package libXpm-devel.i686 0:3.5.10-2.el6 will be installed
---> Package libjpeg-turbo-devel.i686 0:1.2.1-1.el6 will be installed
---> Package libpng-devel.i686 2:1.2.49-1.el6_2 will be installed
---> Package libtidy.i686 0:0.99.0-19.20070615.1.el6 will be installed
---> Package php-cli.i686 0:5.3.3-22.el6 will be installed
---> Package php-common.i686 0:5.3.3-22.el6 will be installed
---> Package php-pdo.i686 0:5.3.3-22.el6 will be installed
---> Package rpm-build.i686 0:4.8.0-32.el6 will be installed
---> Package unixODBC.i686 0:2.2.14-12.el6_3 will be installed
--> Processing Dependency: libltdl.so.7 for package: unixODBC-2.2.14-12.el6_3.i686
---> Package zlib-devel.i686 0:1.2.3-29.el6 will be installed
---> Package fakeroot-libs.i686 0:1.12.2-22.2.el6 will be installed
---> Package keyutils-libs-devel.i686 0:1.4-4.el6 will be installed
---> Package libcom_err-devel.i686 0:1.41.12-14.el6 will be installed
---> Package libselinux-devel.i686 0:2.0.94-5.3.el6_4.1 will be installed
--> Processing Dependency: libsepol-devel >= 2.0.32-1 for package: libselinux-devel-2.0.94-5.3.el6_4.1.i686
--> Processing Dependency: pkgconfig(libsepol) for package: libselinux-devel-2.0.94-5.3.el6_4.1.i686
---> Package libtool-ltdl.i686 0:2.2.6-15.5.el6 will be installed
---> Package libxcb-devel.i686 0:1.8.1-1.el6 will be installed
--> Processing Dependency: pkgconfig(xau) >= 0.99.2 for package: libxcb-devel-1.8.1-1.el6.i686
---> Package xorg-x11-proto-devel.noarch 0:7.6-25.el6 will be installed
---> Package libXau-devel.i686 0:1.0.6-4.el6 will be installed
---> Package libsepol-devel.i686 0:2.0.41-4.el6 will be installed
        Size
Installing:
 gd                          i686    2.0.35-11.el6               base     141 k
 gd-devel                    i686    2.0.35-11.el6               base      78 k
 httpd                       i686    2.2.15-28.el6.centos        updates  828 k
 openssl-devel               i686    1.0.0-27.el6_4.2            updates  1.1 M
 php                         i686    5.3.3-22.el6                base     1.1 M
 php-gd                      i686    5.3.3-22.el6                base     104 k
 php-odbc                    i686    5.3.3-22.el6                base      49 k
 php-pear                    noarch  1:1.9.4-4.el6               base     393 k
 php-pgsql                   i686    5.3.3-22.el6                base      68 k
 php-tidy                    i686    5.3.3-22.el6                base      35 k
 php-xml                     i686    5.3.3-22.el6                base     101 k
 postgresql                  i686    8.4.13-1.el6_3              base     2.8 M
 postgresql-devel            i686    8.4.13-1.el6_3              base     808 k
 postgresql-libs             i686    8.4.13-1.el6_3              base     204 k
 postgresql-server           i686    8.4.13-1.el6_3              base     3.4 M
 rpmdevtools                 noarch  7.5-2.el6                   base     109 k
 rrdtool                     i686    1.3.8-6.el6                 base     294 k
 xinetd                      i686    2:2.3.14-38.el6             base     122 k
Installing for dependencies:
 apr                         i686    1.3.9-5.el6_2               base     129 k
 apr-util                    i686    1.3.9-3.el6_0.1             base      89 k
 apr-util-ldap               i686    1.3.9-3.el6_0.1             base      15 k
 dejavu-lgc-sans-mono-fonts  noarch  2.30-2.el6                  base     393 k
 dejavu-sans-mono-fonts      noarch  2.30-2.el6                  base     450 k
 fakeroot                    i686    1.12.2-22.2.el6             base      74 k
 fakeroot-libs               i686    1.12.2-22.2.el6             base      23 k
 fontconfig-devel            i686    2.8.0-3.el6                 base     209 k
 freetype-devel              i686    2.3.11-14.el6_3.1           updates  364 k
 httpd-tools                 i686    2.2.15-28.el6.centos        updates   73 k
 keyutils-libs-devel         i686    1.4-4.el6                   base      28 k
 krb5-devel                  i686    1.10.3-10.el6_4.3           updates  493 k
 libX11-devel                i686    1.5.0-4.el6                 base     1.0 M
 libXau-devel                i686    1.0.6-4.el6                 base      14 k
 libXpm                      i686    3.5.10-2.el6                base      50 k
 libXpm-devel                i686    3.5.10-2.el6                base      33 k
 libcom_err-devel            i686    1.41.12-14.el6              base      31 k
 libjpeg-turbo-devel         i686    1.2.1-1.el6                 base      96 k
 libpng-devel                i686    2:1.2.49-1.el6_2            base     112 k
 libselinux-devel            i686    2.0.94-5.3.el6_4.1          updates  136 k
 libsepol-devel              i686    2.0.41-4.el6                base      64 k
 libtidy                     i686    0.99.0-19.20070615.1.el6    base     129 k
 libtool-ltdl                i686    2.2.6-15.5.el6              base      45 k
 libxcb-devel                i686    1.8.1-1.el6                 base     174 k
 php-cli                     i686    5.3.3-22.el6                base     2.2 M
 php-common                  i686    5.3.3-22.el6                base     525 k
 php-pdo                     i686    5.3.3-22.el6                base      74 k
 rpm-build                   i686    4.8.0-32.el6                base     127 k
 unixODBC                    i686    2.2.14-12.el6_3             base     382 k
 xorg-x11-proto-devel        noarch  7.6-25.el6                  base     274 k
 zlib-devel                  i686    1.2.3-29.el6                base      44 k
Transaction Summary
Install      49 Package(s)
Total download size: 19 M
Installed size: 71 M
Total                                           1.9 MB/s |  19 MB     00:10
Running Transaction
  Installing : zlib-devel-1.2.3-29.el6.i686                                1/49
  Installing : freetype-devel-2.3.11-14.el6_3.1.i686                       2/49
  Installing : xorg-x11-proto-devel-7.6-25.el6.noarch                      3/49
  Installing : libXau-devel-1.0.6-4.el6.i686                               4/49
  Installing : libxcb-devel-1.8.1-1.el6.i686                               5/49
  Installing : libX11-devel-1.5.0-4.el6.i686                               6/49
  Installing : fontconfig-devel-2.8.0-3.el6.i686                           7/49
  Installing : 2:libpng-devel-1.2.49-1.el6_2.i686                          8/49
  Installing : libjpeg-turbo-devel-1.2.1-1.el6.i686                        9/49
  Installing : libcom_err-devel-1.41.12-14.el6.i686                       10/49
  Installing : dejavu-lgc-sans-mono-fonts-2.30-2.el6.noarch               11/49
  Installing : dejavu-sans-mono-fonts-2.30-2.el6.noarch                   12/49
  Installing : keyutils-libs-devel-1.4-4.el6.i686                         13/49
  Installing : libsepol-devel-2.0.41-4.el6.i686                           14/49
  Installing : php-common-5.3.3-22.el6.i686                               15/49
  Installing : postgresql-libs-8.4.13-1.el6_3.i686                        16/49
  Installing : libXpm-3.5.10-2.el6.i686                                   17/49
  Installing : apr-1.3.9-5.el6_2.i686                                     18/49
  Installing : libselinux-devel-2.0.94-5.3.el6_4.1.i686                   19/49
  Installing : apr-util-1.3.9-3.el6_0.1.i686                              20/49
  Installing : postgresql-8.4.13-1.el6_3.i686                             21/49
  Installing : php-cli-5.3.3-22.el6.i686                                  22/49
  Installing : php-pdo-5.3.3-22.el6.i686                                  23/49
  Installing : httpd-tools-2.2.15-28.el6.centos.i686                      24/49
  Installing : apr-util-ldap-1.3.9-3.el6_0.1.i686                         25/49
  Installing : httpd-2.2.15-28.el6.centos.i686                            26/49
  Installing : krb5-devel-1.10.3-10.el6_4.3.i686                          27/49
  Installing : libXpm-devel-3.5.10-2.el6.i686                             28/49
  Installing : gd-2.0.35-11.el6.i686                                      29/49
  Installing : fakeroot-libs-1.12.2-22.2.el6.i686                         30/49
  Installing : fakeroot-1.12.2-22.2.el6.i686                              31/49
  Installing : rpm-build-4.8.0-32.el6.i686                                32/49
  Installing : libtool-ltdl-2.2.6-15.5.el6.i686                           33/49
  Installing : unixODBC-2.2.14-12.el6_3.i686                              34/49
  Installing : libtidy-0.99.0-19.20070615.1.el6.i686                      35/49
  Installing : rpmdevtools-7.5-2.el6.noarch                               36/49
  Installing : gd-devel-2.0.35-11.el6.i686                                37/49
  Installing : openssl-devel-1.0.0-27.el6_4.2.i686                        38/49
  Installing : 1:php-pear-1.9.4-4.el6.noarch                              39/49
  Installing : php-tidy-5.3.3-22.el6.i686                                 40/49
  Installing : php-odbc-5.3.3-22.el6.i686                                 41/49
  Installing : php-5.3.3-22.el6.i686                                      42/49
  Installing : php-pgsql-5.3.3-22.el6.i686                                43/49
  Installing : postgresql-server-8.4.13-1.el6_3.i686                      44/49
  Installing : postgresql-devel-8.4.13-1.el6_3.i686                       45/49
  Installing : php-gd-5.3.3-22.el6.i686                                   46/49
  Installing : php-xml-5.3.3-22.el6.i686                                  47/49
  Installing : rrdtool-1.3.8-6.el6.i686                                   48/49
  Installing : 2:xinetd-2.3.14-38.el6.i686                                49/49
  Verifying  : apr-util-1.3.9-3.el6_0.1.i686                               1/49
  Verifying  : 2:libpng-devel-1.2.49-1.el6_2.i686                          2/49
  Verifying  : httpd-tools-2.2.15-28.el6.centos.i686                       3/49
  Verifying  : libtidy-0.99.0-19.20070615.1.el6.i686                       4/49
  Verifying  : httpd-2.2.15-28.el6.centos.i686                             5/49
  Verifying  : php-tidy-5.3.3-22.el6.i686                                  6/49
  Verifying  : libtool-ltdl-2.2.6-15.5.el6.i686                            7/49
  Verifying  : php-gd-5.3.3-22.el6.i686                                    8/49
  Verifying  : postgresql-server-8.4.13-1.el6_3.i686                       9/49
  Verifying  : rpmdevtools-7.5-2.el6.noarch                               10/49
  Verifying  : libsepol-devel-2.0.41-4.el6.i686                           11/49
  Verifying  : postgresql-8.4.13-1.el6_3.i686                             12/49
  Verifying  : 1:php-pear-1.9.4-4.el6.noarch                              13/49
  Verifying  : fontconfig-devel-2.8.0-3.el6.i686                          14/49
  Verifying  : php-odbc-5.3.3-22.el6.i686                                 15/49
  Verifying  : keyutils-libs-devel-1.4-4.el6.i686                         16/49
  Verifying  : dejavu-sans-mono-fonts-2.30-2.el6.noarch                   17/49
  Verifying  : zlib-devel-1.2.3-29.el6.i686                               18/49
  Verifying  : unixODBC-2.2.14-12.el6_3.i686                              19/49
  Verifying  : libXau-devel-1.0.6-4.el6.i686                              20/49
  Verifying  : freetype-devel-2.3.11-14.el6_3.1.i686                      21/49
  Verifying  : apr-util-ldap-1.3.9-3.el6_0.1.i686                         22/49
  Verifying  : openssl-devel-1.0.0-27.el6_4.2.i686                        23/49
  Verifying  : php-5.3.3-22.el6.i686                                      24/49
  Verifying  : fakeroot-1.12.2-22.2.el6.i686                              25/49
  Verifying  : php-common-5.3.3-22.el6.i686                               26/49
  Verifying  : gd-devel-2.0.35-11.el6.i686                                27/49
  Verifying  : php-xml-5.3.3-22.el6.i686                                  28/49
  Verifying  : libX11-devel-1.5.0-4.el6.i686                              29/49
  Verifying  : dejavu-lgc-sans-mono-fonts-2.30-2.el6.noarch               30/49
  Verifying  : php-cli-5.3.3-22.el6.i686                                  31/49
  Verifying  : php-pdo-5.3.3-22.el6.i686                                  32/49
  Verifying  : xorg-x11-proto-devel-7.6-25.el6.noarch                     33/49
  Verifying  : postgresql-libs-8.4.13-1.el6_3.i686                        34/49
  Verifying  : libcom_err-devel-1.41.12-14.el6.i686                       35/49
  Verifying  : apr-1.3.9-5.el6_2.i686                                     36/49
  Verifying  : rpm-build-4.8.0-32.el6.i686                                37/49
  Verifying  : libselinux-devel-2.0.94-5.3.el6_4.1.i686                   38/49
  Verifying  : libjpeg-turbo-devel-1.2.1-1.el6.i686                       39/49
  Verifying  : libXpm-devel-3.5.10-2.el6.i686                             40/49
  Verifying  : rrdtool-1.3.8-6.el6.i686                                   41/49
  Verifying  : gd-2.0.35-11.el6.i686                                      42/49
  Verifying  : libxcb-devel-1.8.1-1.el6.i686                              43/49
  Verifying  : 2:xinetd-2.3.14-38.el6.i686                                44/49
  Verifying  : postgresql-devel-8.4.13-1.el6_3.i686                       45/49
  Verifying  : fakeroot-libs-1.12.2-22.2.el6.i686                         46/49
  Verifying  : libXpm-3.5.10-2.el6.i686                                   47/49
  Verifying  : php-pgsql-5.3.3-22.el6.i686                                48/49
  Verifying  : krb5-devel-1.10.3-10.el6_4.3.i686                          49/49
Installed:
  gd.i686 0:2.0.35-11.el6                 gd-devel.i686 0:2.0.35-11.el6
  httpd.i686 0:2.2.15-28.el6.centos       openssl-devel.i686 0:1.0.0-27.el6_4.2
  php.i686 0:5.3.3-22.el6                 php-gd.i686 0:5.3.3-22.el6
  php-odbc.i686 0:5.3.3-22.el6            php-pear.noarch 1:1.9.4-4.el6
  php-pgsql.i686 0:5.3.3-22.el6           php-tidy.i686 0:5.3.3-22.el6
  php-xml.i686 0:5.3.3-22.el6             postgresql.i686 0:8.4.13-1.el6_3
  postgresql-devel.i686 0:8.4.13-1.el6_3  postgresql-libs.i686 0:8.4.13-1.el6_3
  postgresql-server.i686 0:8.4.13-1.el6_3 rpmdevtools.noarch 0:7.5-2.el6
  rrdtool.i686 0:1.3.8-6.el6              xinetd.i686 2:2.3.14-38.el6
Dependency Installed:
Complete!
Adding users and groups...
Users and groups added OK
Initializing PostgresQL...
Initializing database: [60G[[0;32m  OK  [0;39m]
Starting PostgresQL...
Starting postgresql service: [60G[[0;32m  OK  [0;39m]
Restarting PostgresQL...
Stopping postgresql service: [60G[[0;32m  OK  [0;39m]
Database servers initialized OK
iptables: Flushing firewall rules: [60G[[0;32m  OK  [0;39m]
iptables: Setting chains to policy ACCEPT: filter [60G[[0;32m  OK  [0;39m]
iptables: Unloading modules: [60G[[0;32m  OK  [0;39m]
iptables: Applying firewall rules: [60G[[0;32m  OK  [0;39m]
Firewall rules updated OK
cp: cannot stat `nagiosxi/selinux': No such file or directory
SELinux Disabled
Archive:  sourceguardian/ixed4.lin.x86-32.zip
  inflating: /usr/lib/php/modules/ixed.4.3.lin
  inflating: /usr/lib/php/modules/ixed.4.3ts.lin
  inflating: /usr/lib/php/modules/ixed.4.4.lin
  inflating: /usr/lib/php/modules/ixed.4.4ts.lin
  inflating: /usr/lib/php/modules/ixed.5.0.0.lin
  inflating: /usr/lib/php/modules/ixed.5.0.0ts.lin
  inflating: /usr/lib/php/modules/ixed.5.0.1.lin
  inflating: /usr/lib/php/modules/ixed.5.0.1ts.lin
  inflating: /usr/lib/php/modules/ixed.5.0.2.lin
  inflating: /usr/lib/php/modules/ixed.5.0.2ts.lin
  inflating: /usr/lib/php/modules/ixed.5.0.lin
  inflating: /usr/lib/php/modules/ixed.5.0ts.lin
  inflating: /usr/lib/php/modules/ixed.5.1.lin
  inflating: /usr/lib/php/modules/ixed.5.1ts.lin
  inflating: /usr/lib/php/modules/ixed.5.2.lin
  inflating: /usr/lib/php/modules/ixed.5.2ts.lin
  inflating: /usr/lib/php/modules/ixed.5.3.lin
  inflating: /usr/lib/php/modules/ixed.5.3ts.lin
Sourceguardian extension found for PHP version 5.3
Adding Sourceguardian extension to php.ini
Stopping httpd: [60G[[0;31mFAILED[0;39m]
Starting httpd: [60G[[0;32m  OK  [0;39m]
Installed SourceGuardian loaders
Creating product directory...
Reloading httpd:
DATE: Mon Jun 17 16:28:44 EDT 2013
DISTRO INFO:
CentOS
6.4
i686
THIS IS AN UPGRADE!
OLD VERSION:
full=2012R1.5
major=2012
minor=R1.5
release=205
INSTALLING:
full=2012R1.5
major=2012
minor=R1.5
release=205
Yum already configured - exiting.
Prereqs already installed - skipping...
Note: If you want to update the RPMs installed on this system, run 'yum update'
Users/groups already configured - skipping.
Database servers already initialized - skipping.
SELinux Disabled
Sourceguardian already installed
Reloading httpd:
DATE: Tue Jun 18 08:24:20 EDT 2013
DISTRO INFO:
CentOS
6.4
i686
THIS IS AN UPGRADE!
OLD VERSION:
full=2012R1.5
major=2012
minor=R1.5
release=205
INSTALLING:
full=2012R1.5
major=2012
minor=R1.5
release=205
SELinux Disabled
Reloading httpd:
sreinhardt
-fno-stack-protector
Post by sreinhardt »
That is exactly what he meant, and thank you. I would suggest disabling selinux entirely. Likely it is only going to allow a su - postgres and then running postgres commands. Unfortunately our script does not account for that. So try disabling, and re-run the fullinstall.
setenforce disabled
./fullinstall
ssouthern
Post by ssouthern »
I disabled SELinux and have the same issue :(
abrist
Red Shirt
Post by abrist »
What is the output of:
ls -la /root/nagiosfusion/nagiosfusion/create_postgres_db.sh
