Generate Specific Reports
bursatec
Post by bursatec »
How, can I generate specific reports, for example how many hosts have 50% of usage CPU, or how many Filesystems are above 80% of usage.
Regards
abrist
Red Shirt
Re: Generate Specific Reports
Post by abrist »
There is not an efficient way to report on hosts or services based on specific metric thresholds in XI currently.
BanditBBS
Post by BanditBBS »
Well, it wouldn't really be called a report, but you can use the metrics to see this kind of stuff.
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
abrist
Red Shirt
Post by abrist »
BanditBBS wrote:Well, it wouldn't really be called a report, but you can use the metrics to see this kind of stuff.
True enough. With enterprise, you could create reports from those metric pages as well.
bursatec
Post by bursatec »
I have a enterprise license, how can i get a specific report??
BanditBBS
Post by BanditBBS »
bursatec wrote:I have a enterprise license, how can i get a specific report??
On the main page, under the details section of the menu you should see "metrics"
Go look there and play around, you can see CPU usage, drive usage and other items.
abrist
Red Shirt
Post by abrist »
Use the "Metrics" component under Home --> Details. Choose your desired options from the dropdowns and then click the "schedule page" clock icon in the upper right hand corner.
EDIT: forum race condition. . .
bursatec
Post by bursatec »
Thanks!!!
The solution works for me, but how can i Add more metrics, because i only have:
Disk Usage
CPU Usage
Memory
Load
Swap
And the CPU Usage Metric only return me the Windows servers metrics, but the Linux and AIX metrics are missing.
Can you help me with that.
Best Regards
BanditBBS
Post by BanditBBS »
bursatec wrote:Thanks!!!
The Linux and AIX should be under the LOAD. I can't answer about the adding newer metrics.
abrist
Red Shirt
Post by abrist »
Bandit is correct, CPU Usage is windows specific, whereas LOAD is linux specific.
