more services matching string
blackpuma
Post by blackpuma »
Dear people,
I want to check services on a Server 2008 R2. This is working fine but I get an warning because more services are found. I have two services which starts with the same string but at the second is test added.
How can I use exactly the service name?
BR
Re: more services matching string
Post by slansing »
What are you currently using to check the services running? Are you trying to find a way to verify a certain group of services are running, and if a new service is added you should get a warning or critical?
blackpuma
Post by blackpuma »
I'm using
check_xi_serivce_snmp_win_service! -C public --v2c -n 'MSSQLSER'
I get a warning that 2 services are found.
One is the "MSSQLSERVER" and the second one is "MSSQLSERVERADHelper100". But I just want the "MSSQLSERVER".
BR
Post by slansing »
Can you share the full command definition with us? You should be able to place an exclusion rule in the command.
Open CCM > Commands > Find the command's name and share the string with us. Thanks!
blackpuma
Post by blackpuma »
Sorry for being so late.
Here is the string:
$USER1$/check_snmp_win.pl -H $HOSTADDRESS$ $ARG1$
BR
Post by slansing »
It looks like it will try to match any service with the defined text, so it will include the additional one as well. Have you considered using NSClient++ to check the true service name via the Windows Server monitoring wizard?
blackpuma
Post by blackpuma »
I solved it now. I use the -r switch so I can match the exact name of the service.
In my case:
check_xi_service_snmp_win_service! -C public --v2c -n 'SQL Server (MSSQLSERVER)' -r
BR
