I have seen this on a few other posts and tried what was listed there.
When I run the plugin on the cli everything comes back good.
when I run it as a scheduled check in XI I just get a Status (null)
[nagios@nagios1 libexec]$ ./SRS_check_rhev3 -H rhevm.cloud2 -f .authfile -R rhhva.cloud2 -l cpu
RHEV OK: cpu ok - 4% used (rhhva.cloud2.srs.local) |cpu=4%;60;80;0; cpu.current.user=1;;;0; cpu.current.system=2;;;0; cpu.current.idle=96;;;0;
This is the check_rhev3 plugin from the exchange, downloaded from git_hub. the SRS prefix is just a rename of the file for standardizing local usage. the command works the same with or without the rename.
there is already this at the top
#!/usr/bin/perl -w
# nagios: -epn
so it isn't trying to use the embedded perl.
Any thoughts?
Nagios XI 2012R1.3
Plugin executes on CLI not in XI
Re: Plugin executes on CLI not in XI
Can you provide a direct link to the plugin?
SRSPharmacy
Can you show us the command, and service definition for the check in question?
SRSPharmacy
command def.
command_name SRS_check_rhev_cpu_cloud2
command_line $USER1$/SRS_check_rhev3 -H rhevm.cloud2 -f .authfile -R rhhva.cloud2 -l cpu
# Service configuration file
# Created by: Nagios QL Version 3.0.3
# Date: 2013-06-28 10:52:32
# Version: Nagios 3.x config file
# Nagios QL will overwite all manual settings during the next update
host_name rhhva.cloud2.srs.local
service_description rhhva.cloud2 - CPU
display_name rhhva.cloud2 - CPU Utilization
check_command SRS_check_rhev_cpu_cloud2!!!!!!!!
register 1
register 1
sreinhardt
- -fno-stack-protector
Where is this .authfile located? by default nagios sets the working directory as /home/nagios, so if it is in the libexec dir you might want to alter the flag to :
-f $USER1$/.authfile
edit: I should note that it might require a little escaping with the / in there, but hopefully not.
SRSPharmacy
ah ha! That did it. Thanks!
Great! Closing as resolved.
