1) I want to remove the logs of the process which is utilizing my CPU resource, eg In the task manger of windows machine we see the list of process which utilizes the CPU.
How can i remove logs and also reports which specify which process is using my CPU resource.
2) As alerts are sent through email and [email protected] sends the email. Can we edit the sender e-mail ID from root.nagios.com to any other e-mail ID
Nagios Query
Re: Nagios Query
1) I'm not sure what you are asking here..?
2) Yes, you can change this by following a guide like this one which will guide you on configuring your MTA:
http://www.telnetport25.com/2012/02/con ... gios-core/
Re: Nagios Query
hello,
Please go through the pdf report attached for better understanding.
How can i remove the same report for applications that are running for a monitoring server.
Please ignore the Graph in the pdf.
Re: Nagios Query
Closing this thread as it is a near duplicate of your Netflow thread. Please follow up there.
