Servicegroup escalation
BanditBBS
Post by BanditBBS »
If you look here http://support.nagios.com/forum/viewtop ... 897#p56356 it was stated that you can not escalate by servicegroups.
However, if you look here http://nagios.sourceforge.net/docs/3_0/ ... escalation and then search for "All Services In Multiple Servicegroups:" it does say you can escalate by servicegroups. I was about to start configuring this and want to know, which is correct, the documentation or the forum post?
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Re: Servicegroup escalation
Post by slansing »
You can select multiple services "in the case of the XI escalation wizard." But servicegroups are not listed there. In core, due to the differences in how default configurations are created and read you can use the core definitions. How/where are you starting to define these?
BanditBBS
Post by BanditBBS »
slansing wrote:You can select multiple services "in the case of the XI escalation wizard." But servicegroups are not listed there. In core, due to the differences in how default configurations are created and read you can use the core definitions. How/where are you starting to define these?
In static config files. This all goes back to my on-call rotation handling. So, does this mean I will be able to use it since I am doing in static configs?
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Based on the documentation provided, it would certainly seem that you can escalate service groups with static configs. It's certainly not something seen often though.
BanditBBS
Post by BanditBBS »
sreinhardt wrote:Based on the documentation provided, it would certainly seem that you can escalate service groups with static configs. It's certainly not something seen often though.
Well, I'll be attempting it and adding to my documentation for the World Conference if it works :)
BanditBBS
Post by BanditBBS »
Tested and verified working, and working great! Feel free to lock thread.
Post by slansing »
Awesome! Looking forward to seeing it in the presentation! :)
