What is the process to update a NRDS Client with a new Nagios XI Server to send results to?
Is it simply updating the configuration file on each client, or is there a way to do it from the Nagios server?
Reconfigure NRDS Client's to point to New XI Server
matt.uebel
Re: Reconfigure NRDS Client's to point to New XI Server
You will need to change the NRDP address, and token in the config.ini file for the client, then restart cron, or the service/scheduled task depending on what OS/type of NRDS you are using.
