Recurring downtime
WillemDH
Recurring downtime
Post by WillemDH »
Got some questions about recurring downtime.
1) Is a host goes into downtime, should this hosts service also go into downtime? Or should its services stop sending notifications?
2) It should be possible to specify a service in the recurring downtime page:
"Optional service associated with this schedule. A wildcard can be used to specify multiple matches (e.g. 'HTTP*'). "
However when I try to use a wildcard, for example EVT_*, I get "The service you specified is not valid for your user account." I tried using single and double quotas, but same problem.
3) Can I specify multiple service for a host? I tried with comma's and semicolons, but didn't work.
Tx
Nagios XI 5.8.1
https://outsideit.net
Re: Recurring downtime
Post by slansing »
The services do not enter downtime on their own when using Scheduled Downtime "the core version," with Recurring Downtime you have the option to also specify services under a host to bring into downtime, it is the second field you will see when scheduling Host Downtime. Unfortunately it looks like there is a bug with using a wildcard to specify multiple services, I am going to get in contact with a dev about this when he is out of his meeting.
WillemDH
Post by WillemDH »
It seems this has been solved in one of the latest patches. Thread can be closed.
Nagios XI 5.8.1
