Am I running Standard or Enterprise version?
kjhosein
Post by kjhosein »
Hello all,
I just inherited a Nagios XI system, and I'm trying to figure out if I've got the Standard or Enterprise version. I found the file nagiosxi/var/xiversion, but it doesn't indicate that distinction.
Thanks!
_Khalid
Re: Am I running Standard or Enterprise version?
Post by slansing »
It looks like your company currently uses one standard license.
kjhosein
[SOLVED] Re: Am I running Standard or Enterprise version?
Post by kjhosein »
Thanks!
And I just ran across the screen in the web console that describes the license: go to Admin (at the top), then click License Information under System Config in the side navbar.
Correct.
