How do I resolve the following config file error?
Is there a workaround to carete these missing config files?
contacttemplates.cfg
contacts.cfg....
[root@ltenav1 etc]# /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
Nagios Core 3.2.2
Copyright (c) 2009-2010 Nagios Core Development Team and Community Contributors
Last Modified: 09-01-2010
License: GPL
Reading configuration data...
Read main config file okay...
Processing object config directory '/usr/local/nagios/etc/static'...
Processing object config file '/usr/local/nagios/etc/static/xitemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xitest.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xiobjects.cfg'...
Processing object config file '/usr/local/nagios/etc/contacttemplates.cfg'...
Error: Cannot open config file '/usr/local/nagios/etc/contacttemplates.cfg' for reading: No such file or directory
configuration file error
Re: configuration file error
I'm seeing this as being related to the install issues from your other thread. I was starting to run a test install today on CentOS 5.5, and I ran into several of the same error messages as you did. I haven't pinned down the issue yet, but we'll let you know as soon as I find it.
ericsson_att
I would appreciate a quick turn around solution for this, if possible. Thank you for your post though.
ericsson_att
Our team could somehow made Nagios XI work (by creating postgres db by running ./B script changing permissions and owner as desired and by creating all cfg files necessary that are missing manually and by editing with the required info). Not sure if that would suffice, but then, nothing works in the config tab on the right pane, all others seem to be working fine. This is of great concern at this time.
Shall wait for your fix though.
