does the XI integrated Availability Report include only hard alarms or does it also include soft alarm states in the avalability calculation?
Thanks and kind regards
Availability Report / Soft+Hard States
Re: Availability Report / Soft+Hard States
Soft states are not included in the availability report, unless the object then continues to a hard state. When that happens, downtime is reported from the last HARD OK state to the next HARD OK state.
