Riverbed plugin
NagiosNewbis
Riverbed plugin
Post by NagiosNewbis »
Hi;
Does anyone know the configuration of Riverbed plugin? I put to my Nagios Core but it display "Criticals" in Status column without status information. This plugin downloaded from here "https://code.google.com/p/nagios-riverb ... loads/list", what will be check with using this plug in? And how to configure it properly to show the correct information?
I am attaching two files for reference, the riverbed_obj.cfg and the commands.cfg.
riverbed_obj.cfg..txt
Riverbed object config
(1.23 KiB) Downloaded 370 times
commands.cfg.txt
Commands
(202 Bytes) Downloaded 362 times
NagiosNewbis
Re: Riverbed plugin
Hi;
after looking to the error message I found, I doubt, it is caused by the Error.pm module of Perl is not installed. How can I install the Error.pm properly?
I tried this
perl -MCPAN -e 'install Error'
but return that
Result: FAIL
Failed 13/15 test programs. 0/10 subtests failed.
make: *** [test_dynamic] Error 2
SHLOMIF/Error-0.17020.tar.gz
/usr/bin/make test -- NOT OK
//hint// to see the cpan-testers results for installing this module, try:
reports SHLOMIF/Error-0.17020.tar.gz
Warning (usually harmless): 'YAML' not installed, will not store persistent state
Running make install
make test had returned bad status, won't install without force
jsmurphy
Re: Riverbed plugin
Post by jsmurphy »
It's trying to install SHLOMIF Error.pm so it's not a problem with the core perl Error.pm
You can find it here: http://search.cpan.org/~shlomif/Error-0 ... b/Error.pm
The only way to install it may be to try and force it... It's a deprecated plugin, so it may not install correctly on all distros any more.
Re: Riverbed plugin
Post by slansing »
Thanks Jsmurphy,
NagiosNewbis, let us know how well this works for you, though we cannot guarantee that you will be able to use this plugin properly.
