nagios backup script question
benhank
Post by benhank »
Hello all!
What do I need to do to make the nagios backup script use regular time instead of unix time?
And would I have to make any changes to the restore script?
(stop laffin..)
Proudly running:
Nagios Network Analyser
Nagios Fusion
abrist
Red Shirt
Re: nagios backup script question
Post by abrist »
Copy the script first as XI upgrades will overwrite it (DISCLAIMER - When we change the script for necessary upgrades, you will have to reapply the following, assuming the following will still work):
cp /usr/local/nagiosxi/scripts/backup_xi.sh /usr/local/nagiosxi/scripts/backup_xi_benhank_style.sh
On line 110 of the script backup_xi_benhank_style.sh, add the following:
bhts=$(date +"%m-%d-%y")
mv $ts.tar.gz "$bhts".tar.gz
echo "Backup is actually stored in $rootdir/$bhts.tar.gz"
echo "*Not* where the script will tell you it is below, it lies!"
bhts = benhank timestamp or better human timestamp :P
As always, give it a test. The restore procedure should work as it grabs the filename passed to it and loads it into a variable. As there are no spaces in this name, it should work ok, though it does not include hours, minutes, etc. Let me know if you have issues with it.
benhank
Post by benhank »
As they day in the shaft song" You >censored< riiiight!"
thanks you can lock it up. =D
Proudly running:
Nagios Fusion
abrist
Red Shirt
Post by abrist »
THEN WE CAN DIG IT!
