Nagios Query
Mike
Nagios Query
Post by Mike »
Can nagios monitor Syslog events Co-relation and analyz it.
If yes,can you please send me the solution for the same.As i tried through plugins but i have not found the exact plugin.
.WHich is the proper plugin or other solution for the same.
Re: Nagios Query
Post by slansing »
I'm not sure what exactly you would like the plugin to do, but there is a good sized selection of log monitoring plugins located here:
http://exchange.nagios.org/directory/Ad ... Management
And here:
http://exchange.nagios.org/directory/Plugins/Log-Files
Are you looking to match strings? We need a bit more specifics before we can give a solid answer.
