Autodiscovery SNMP String
tcknabe
Post by tcknabe »
How can I change the SNMP string from default "public" to my custom public RO community string? I have a custom public string set on all my routers worldwide.
abrist
Red Shirt
Re: Autodiscovery SNMP String
Post by abrist »
You should be able to change the community string the in CCM for each of the devices:
Go to --> Configure --> Core Config Manager --> Services --> click on the service in question, change 'public' in the arguments to your community string.
If the snmp enabled device in question has a large number of ports, you may want to to add it through the switch and router wizard.
