Agent On Windows Server 2012
I need to install the agent for Nagios XI on Windows Server 2012 64bit, I have to use the same procedure of installation the Agent on Windows Server 2008 64bit
Re: Agent On Windows Server 2012
Yes if you are referring to Nsclient++ the installation procedure is the same, via a MSI installer.
