Is it possible, iether now or in a future release, to have nagios send out a notification when there has been a change to the system?
for ex:
nuckleh... I mean a user makes a change and does an apply config, I know that that is saved in the audit log, but can we get an email as well?
nagios email notification request
Proudly running:
Nagios Network Analyser
Nagios Fusion
Nagios Fusion
Re: nagios email notification request
Hmm, this sounds quite useful, would you be able to send us a feature request?:
http://tracker.nagios.com/
that all depends... how much $$ do I get if yall use the idea (times are tuff bro you know how it is, gotta stay on top of those cable bills)? heh heh. jk ok i will you can lock this.
Proudly running:
Nagios Fusion
Nagios Fusion
Haha sounds good.
