Nagios Login page
sujitt
Nagios Login page
Post by sujitt »
the forgot password feature on the nagios login page is very insecurely implemented. It gives way for anybody be able to reset the password of any user without verification.
Can we make this more secure or some way to protect admin passwords from being reset ?
abrist
Red Shirt
Re: Nagios Login page
Post by abrist »
Not necessarily insecure, but it definitely allows for vagrants to be rather annoying. I will open an internal bug fix for this. The email should probably give you a link to reset the password instead of the "Forgot Password" link resetting the password itself. Thanks for the heads up.
cmerchant
Post by cmerchant »
This fix was rolled into the source trunk and should be in the most recent version of Nagios XI.
