mrtg error
zaji_nms
mrtg error
Post by zaji_nms »
Dear Support,
we are running nagiosxi 2012R1.7 on following platform we are getting error in mrtg file . at present file size is 3.2Mb and we will be adding up to 30Mb . we need immediate solution or fix for it.
Linux c1nms.zajil.com 2.6.32-358.2.1.el6.x86_64 #1 SMP Wed Mar 13 00:26:49 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
[root@c1nms mrtg]# ll
total 16100
-rw-r--r-- 1 root root 3210270 Jul 15 09:47 mrtg.cfg
2013-07-15 09:50:01 -- 2013-07-15 09:50:01: ERROR: I guess another mrtg is running. A lockfile (/var/lock/mrtg/mrtg_l) aged
300 seconds is hanging around. If you are sure that no other mrtg
is running you can remove the lockfile
2013-07-15 09:55:01 -- Started mrtg with config '/etc/mrtg/mrtg.cfg'
2013-07-15 10:55:01 -- Started mrtg with config '/etc/mrtg/mrtg.cfg'
2013-07-15 11:00:01 -- Started mrtg with config '/etc/mrtg/mrtg.cfg'
2013-07-15 11:00:01 -- 2013-07-15 11:00:01: ERROR: I guess another mrtg is running. A lockfile (/var/lock/mrtg/mrtg_l) aged
Zajil NMS
Re: mrtg error
Post by slansing »
Do you have multiple MRTG.cfg files split apart? Do you have a extended timeout on any of the objects within this config, or these configs?
Please share the output of the following:
cat /etc/cron.d/mrtg
zaji_nms
Re: mrtg error
Post by zaji_nms »
no we dont have multiple mrtg.cfg nor its splited. all hosts avg response time is between 1-10ms.
*/5 * * * * root LANG=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /var/lock/mrtg/mrtg_l --confcache-file /var/lib/mrtg/mrtg.ok --logging /var/log/mrtg.log
Zajil NMS
Re: mrtg error
Is you system under heavy load during certain periods? It's possible that your polling is taking longer than the 5 min interval you've set in the crontab. Try changing the interval to 10 min (for testing purposes), and see if this is going to eliminate the issue.
